Hello
my Telegram Plugin says - OK - if I press Test.
The API token is fine, just checked and copied from Telegram botfather.
but I never get any info to Telegram?
commands are all checked
notification print done, failed .... checked
What can I do, where can I look at?
Telegram 1.6.5
THX
Honestly, I took it out of duty since a boot command got stuck in the input buffer and the Pi was left in a boot loop.
I use OctoPod since then.
OK, thanks, what is OctoPod? a Plugin?
installed iPhone App, settings done to printer
Octopod Plugin on Octoprint installed
under printer, my iPhone is registered
on the iPhone I can see the web cam
but I get an error during Test send
(where can I finde the log?)
connected via the old api key
Thx
do I need to open ports on my Fritz! manually?
OK, I do not finde the problem.
do you know where I can finde the log?
They may be in the systeminfo bundle
2022-04-19 18:30:25,525 - octoprint.plugins.octopod - WARNING - Could not send message: HTTPConnectionPool(host='octopodprint.com', port=80): Max retries exceeded with url: //v1/push_printer (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x69553350>: Failed to establish a new connection: [Errno 101] Network is unreachable'))
I think I have got the problem, the pi cannot connect to web
this is my settings:
OK, this was the problem, solved. running. THX!
I think that was the initial issue with Telegram too
