loaded the plugin and ctrl F5 to reload.
The new Temp panel does not appear in the list of SideBars in the plugin settings, so added with the ' + ' and moved it up and Saved.
Did ctrl F5 again but order of sidebars has not changed.
I didn't write that plugin, so you'll need ti pat. Tp that repositories issues for help but it was a fork ofKy tab order plugin, which I know the text had to be entered a very specific way in order to work.
Have looked at the SideBarOrder plugin but having tried every 'name' that I can think of, still can't get it to change the position of the Sidebar Temp Graph.
Also can not find any way to contect the author of the SideBarOrder plugin.
Anyone here want to try figure out why it is not working with Sidebar Temp Graph and fix it ?
Looks like a perfect plugin, if it can be made to recognise the sidebar panel
I got it working by using the name plugin_sidebartempgraph. Once you save you have to actually restart octoprint and then force a refresh with ctrl+f5.
Awesome. Needed a guru like you to figure it out. Hope you make mention on the plugin page for the Sidebar Temp Graph.
Thanks again.
