Learning Octoprint with my stock CR-10s.
I installed the “Terminal Commands” plug in. So now I have a button to press that enters my calculated (M92 Exx.xx) “Filiment Feed Rate”.
Question: Does this new feed rate override previous default “Feed Rates”?
If it does then before EVERY print starts I simply press my MAGIC button for proper rate.
What's about putting your M92 Exx.xx in the start gcode?
Settings -> GCODE Scripts -> Before print job starts
Then you do not need to think about it to press the "magic" button ...
