Terminal Window not wide enough - any way to change?
Got Btt GTR and M5 with 11 motor channels. UART check has to long lines for terminal window. All informations are wrapped to the next line at different columns. Comparing the values is nearmost impossible. Any way to widen the terminal window to fit longer lines?
You can use Themeify to make elements wider using the advanced options. Check this post for more details.
