I'm not sure where to post this, hopefully this is a reasonable spot!
I installed the themify plugin (1.2.2) on octoprint (1.10.3). I prefer dark mode themes, so I set it to 'Discorange' (I'm an opnsense fan, and the ui mostly matches the cicada theme there!).
All works well, the main octoprint screen and all sub-pages have the theme applied. But the initial logon screen as well as the initial messages (connecting to.... loading octoprint ui....) are all default brite white.
Any easy way to have the theme apply to those as well?
Thanks in advance for any advice/pointers!
I'd recommend switching to a plugin that is actively maintained. You should check out UI Customizer, it has theming plus a whole lot more, and even includes my discoranged theme that I ported over from Themify.
Thank you so much for the guidance.
I will try ui customizer. Perhaps that will also allow me to get rid of floating navbar plugin too
The only thing I found in themify's discoranged theme I didn't like was slider toggle buttons were black and hard to see, was going to look into changing that but will just try ui customizer first.
Yeah, floating navbar is not necessary with UI Customizer, it has that option as well as some of the other options available in some of my other one off plugins, like tab order and sidebar temp graph.
Thanks again! UI customizer is very nice, thats a keeper. I did notice that floating navbar was included so just to be safe I removed any plugins I had already installed that impacted the UI, then added ui customizer, and am now only adding back the ones I can tell aren't included.
I was using 'navbar temp', but switched to 'top temp' as it has more features. I am suprised it shows my cpu temp as 53C (creality ender 3 original and raspi 3B+). Fan is running but that seems hot for idle-just-turned-on.... I installed the 'resource monitor' plugin, and it shows 53C as well for cpu temp.
I have the latest th3d uf2 (as of yesterday), so I think that means I dont need any of the 'creality ender 3 temp fix' plugins. I think I read that the firmware fixes those.
I have no camera attached yet, but may be using a logitech C920 and going to install 'camera settings' plugin next.
