Timing estimates between pause commands
Hi guys,
I was wondering if anyone knew of a plugin that does something like printtimegenius but instead does the calculations on sections of the gcode, like from the current position to the next M600 command, then to the next M600 command if there is one, eventually to the end of the code. I want to do some more with M600 stuff but I'd like to have a better idea when I need to be back at the printer to switch filament and stuff.
I'm thinking about making this myself if it doesn't exist, but I haven't made an octoprint plugin before so I'm hoping one already exists that I can just go ahead and use.
Thanks!
I'm not aware of any plugins like that.
Hi @mjmr89,
take a look into DisplayLayerProgress-Plugin (https://github.com/OllisGit/OctoPrint-DisplayLayerProgress).
Since Version 1.18.0 the mentioned feature is included.
See ticket https://github.com/OllisGit/OctoPrint-DisplayLayerProgress/issues/115 for more details.
Because I don't have a printer that supports M600, I need the feedback from the testers....so, there is (maybe) room for improvements.
C ya,
Olli
