[Tip] A cheap 1080p PTZ camera that works with Octoprint
Wanted to give you all a quick tip on a cheap camera for your 3d printer that can also be used with Octoprint
I saw a lot of posts on different forums about is and people are looking for a cheaper alternative but struggle to use them
Sonoff GK-200MP2B
  • 1080p
  • Pan and Tilt
  • Mic
  • Wifi
There is RTSP support but it's not supported on Octoprint out of the box
There is a way to run a ffmpeg server, but it does use CPU on your Raspberry
I wanted something that doesn't add overhead like the raspberry native camera but I also wanted a mic and pan&tilt so I can hear what going on and change angles
So I'm using the Sonoff, with this hack
Which give me a URL to a 1080p h264 snapshot
And I use SnapStream Octoprint plugin to see a feed from the cam
This way I offloaded all the heavy lifting to the camera cpu
This also works with Octolapse
Its a better option then connection a camera to the raspberry usb (like many do with the wyze)
The camera is 29$ (aliexpress)
SD card 3-5$ (mandatory if you want the hack to octoprint)
