I'm trying to use the change filament plugin but seeing the following message when trying to use it...
Send: G1 E-500 F1600
Recv: echo: too long extrusion prevented
Can this maximum extrusion be set in the printer profile or overridden with a connection GCODE?
Dan
Afaik you can change this variable only before building marlin.
Prevent Lengthy Extrude
#define PREVENT_LENGTHY_EXTRUDE
#define EXTRUDE_MAXLENGTH 200
A lengthy extrusion may not damage your machine, but it can be an awful waste of filament. This feature is meant to prevent a typo or glitch in a G1 command from extruding some enormous amount of filament. For Bowden setups, the max length should be set greater than or equal to the load/eject length.
Source
its for Filament Change plugin - it doesn't work because it blocks the extrude command.
I changed to a bondtech and miss the little dial that I printed for the stock extruder winding in and out the filament. Turning the cog by hand is tearing up my thumb and its a pain having to hold the extruder open to withdraw.
