Safe mode did not correct the issue.
Here is serial
2022-05-08 20:31:58,243 - Changing monitoring state from "Offline" to "Detecting serial connection"
2022-05-08 20:31:58,305 - Performing autodetection with 7 port/baudrate candidates: /dev/ttyUSB0@115200, /dev/ttyUSB0@250000, /dev/ttyUSB0@230400, /dev/ttyUSB0@57600, /dev/ttyUSB0@38400, /dev/ttyUSB0@19200, /dev/ttyUSB0@9600
2022-05-08 20:31:58,306 - Trying port /dev/ttyUSB0, baudrate 115200
2022-05-08 20:31:58,307 - Connecting to port /dev/ttyUSB0, baudrate 115200
2022-05-08 20:31:58,379 - Handshake attempt #1 with timeout 2.0s
2022-05-08 20:31:58,380 - Connected to: Serial<id=0xaf296930, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2022-05-08 20:31:58,382 - Send: N0 M110 N0125
2022-05-08 20:31:59,278 - Recv: start
2022-05-08 20:31:59,286 - Changing monitoring state from "Detecting serial connection" to "Operational"
2022-05-08 20:31:59,316 - Send: N0 M110 N0125
2022-05-08 20:31:59,318 - Recv: echo:Marlin 0.4.0-Marlin2.x
2022-05-08 20:31:59,320 - Recv:
2022-05-08 20:31:59,322 - Recv: echo: Last Updated: 2022-02-18 | Author: Longer3D, Hobi, tpruvot
2022-05-08 20:31:59,326 - Recv: echo:Compiled: Feb 18 2022
2022-05-08 20:31:59,329 - Recv: echo: Free Memory: 2842 PlannerBufferBytes: 1200
2022-05-08 20:31:59,336 - Recv: echo:EEPROM version mismatch (EEPROM=? Marlin=V76)
2022-05-08 20:31:59,338 - Recv: echo:Hardcoded Default Settings Loaded
2022-05-08 20:32:00,206 - Recv: echo:SD card ok
2022-05-08 20:32:00,221 - Recv: Detect touch screen: DWIN T5
2022-05-08 20:32:01,229 - Recv: ok
2022-05-08 20:32:01,234 - Send: N1 M11539
2022-05-08 20:32:01,255 - Recv: FIRMWARE_NAME:Marlin 0.4.0-Marlin2.x (GitHub) SOURCE_CODE_URL:LONGER3D (Longer3D) Β· GitHub PROTOCOL_VERSION:1.0 MACHINE_TYPE:Longer3D LK5 Pro EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
2022-05-08 20:32:01,262 - Recv: Cap:SERIAL_XON_XOFF:0
2022-05-08 20:32:01,268 - Recv: Cap:BINARY_FILE_TRANSFER:0
2022-05-08 20:32:01,279 - Recv: Cap:EEPROM:1
2022-05-08 20:32:01,281 - Recv: Cap:VOLUMETRIC:1
2022-05-08 20:32:01,283 - Recv: Cap:AUTOREPORT_TEMP:1
2022-05-08 20:32:01,288 - Recv: Cap:PROGRESS:0
2022-05-08 20:32:01,291 - Recv: Cap:PRINT_JOB:1
2022-05-08 20:32:01,293 - Recv: Cap:AUTOLEVEL:0
2022-05-08 20:32:01,294 - Recv: Cap:Z_PROBE:0
2022-05-08 20:32:01,295 - Recv: Cap:LEVELING_DATA:0
2022-05-08 20:32:01,297 - Recv: Cap:BUILD_PERCENT:0
2022-05-08 20:32:01,298 - Recv: Cap:SOFTWARE_POWER:0
2022-05-08 20:32:01,299 - Recv: Cap:TOGGLE_LIGHTS:0
2022-05-08 20:32:01,300 - Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
2022-05-08 20:32:01,301 - Recv: Cap:EMERGENCY_PARSER:0
2022-05-08 20:32:01,302 - Recv: Cap:PROMPT_SUPPORT:0
2022-05-08 20:32:01,303 - Recv: Cap:AUTOREPORT_SD_STATUS:0
2022-05-08 20:32:01,305 - Recv: Cap:THERMAL_PROTECTION:1
2022-05-08 20:32:01,306 - Recv: Cap:MOTION_MODES:0
2022-05-08 20:32:01,307 - Recv: Cap:CHAMBER_TEMPERATURE:0
2022-05-08 20:32:01,308 - Recv: ok
2022-05-08 20:32:01,309 - Send: M21
2022-05-08 20:32:01,319 - Recv: echo:SD card ok
2022-05-08 20:32:01,320 - Recv: ok
2022-05-08 20:32:01,321 - Send: M20
2022-05-08 20:32:01,323 - Recv: Begin file list
2022-05-08 20:32:01,327 - Recv: LK5PRO~1.GCO 2104012
2022-05-08 20:32:01,329 - Recv: LK5PRO~2.GCO 3926224
2022-05-08 20:32:01,332 - Recv: LK5PRO~3.GCO 322307
2022-05-08 20:32:01,333 - Recv: LK5PRO~4.GCO 11426693
2022-05-08 20:32:01,335 - Recv: LKD106~1.GCO 1880327
2022-05-08 20:32:01,607 - Recv: LLK5PR~1.GCO 0
2022-05-08 20:32:01,620 - Recv: End file list
2022-05-08 20:32:01,621 - Recv: ok
2022-05-08 20:32:01,622 - Send: M155 S2
2022-05-08 20:32:01,628 - Recv: ok
2022-05-08 20:32:03,636 - Recv: T:59.96 /0.00 B:52.95 /0.00 @:0 B@:0
2022-05-08 20:32:05,636 - Recv: T:59.39 /0.00 B:52.86 /0.00 @:0 B@:0
2022-05-08 20:32:07,636 - Recv: T:58.84 /0.00 B:52.73 /0.00 @:0 B@:0
2022-05-08 20:32:09,635 - Recv: T:58.33 /0.00 B:52.71 /0.00 @:0 B@:0
2022-05-08 20:32:11,635 - Recv: T:57.81 /0.00 B:52.56 /0.00 @:0 B@:0
2022-05-08 20:32:13,635 - Recv: T:57.29 /0.00 B:52.50 /0.00 @:0 B@:0
2022-05-08 20:32:15,441 - Changing monitoring state from "Operational" to "Starting"
2022-05-08 20:32:15,473 - Send: N0 M110 N0125
2022-05-08 20:32:15,490 - Recv: ok
2022-05-08 20:32:15,500 - Changing monitoring state from "Starting" to "Printing"
2022-05-08 20:32:15,506 - Send: N1 M140 S6082
2022-05-08 20:32:15,510 - Recv: ok
2022-05-08 20:32:15,512 - Send: N2 M10537
2022-05-08 20:32:15,530 - Recv: ok T:56.88 /0.00 B:52.41 /60.00 @:0 B@:0
2022-05-08 20:32:15,533 - Send: N3 M190 S6093
2022-05-08 20:32:15,544 - Recv: T:56.78 /0.00 B:52.36 /60.00 @:0 B@:0 W:?
2022-05-08 20:32:15,635 - Recv: T:56.78 /0.00 B:52.36 /60.00 @:0 B@:0
2022-05-08 20:32:16,544 - Recv: T:56.60 /0.00 B:52.36 /60.00 @:0 B@:0 W:?
2022-05-08 20:32:17,546 - Recv: T:56.34 /0.00 B:52.30 /60.00 @:0 B@:0 W:?
2022-05-08 20:32:17,548 - Recv: echo:busy: processing
2022-05-08 20:32:17,548 - Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
2022-05-08 20:32:17,635 - Recv: T:56.34 /0.00 B:52.30 /60.00 @:0 B@:0
2022-05-08 20:32:18,544 - Recv: T:56.05 /0.00 B:52.26 /60.00 @:0 B@:0 W:?
2022-05-08 20:32:19,546 - Recv: T:55.83 /0.00 B:52.24 /60.00 @:0 B@:0 W:?
2022-05-08 20:32:19,553 - Recv: echo:busy: processing
2022-05-08 20:32:19,635 - Recv: T:55.82 /0.00 B:52.26 /60.00 @:0 B@:0
2022-05-08 20:32:20,544 - Recv: T:55.61 /0.00 B:52.20 /60.00 @:0 B@:0 W:?
2022-05-08 20:32:21,545 - Recv: T:55.42 /0.00 B:52.16 /60.00 @:0 B@:0 W:?
2022-05-08 20:32:21,552 - Recv: echo:busy: processing
2022-05-08 20:32:21,636 - Recv: T:55.42 /0.00 B:52.10 /60.00 @:0 B@:0
2022-05-08 20:32:22,544 - Recv: T:55.21 /0.00 B:52.07 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:23,545 - Recv: T:54.99 /0.00 B:52.09 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:23,552 - Recv: echo:busy: processing
2022-05-08 20:32:23,636 - Recv: T:54.91 /0.00 B:52.06 /60.00 @:0 B@:127
2022-05-08 20:32:24,544 - Recv: T:54.77 /0.00 B:52.05 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:25,544 - Recv: T:54.49 /0.00 B:52.14 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:25,553 - Recv: echo:busy: processing
2022-05-08 20:32:25,635 - Recv: T:54.49 /0.00 B:52.14 /60.00 @:0 B@:127
2022-05-08 20:32:26,545 - Recv: T:54.29 /0.00 B:52.26 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:27,544 - Recv: T:54.03 /0.00 B:52.34 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:27,550 - Recv: echo:busy: processing
2022-05-08 20:32:27,635 - Recv: T:54.03 /0.00 B:52.34 /60.00 @:0 B@:127
2022-05-08 20:32:28,545 - Recv: T:53.81 /0.00 B:52.50 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:29,544 - Recv: T:53.59 /0.00 B:52.71 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:29,547 - Recv: echo:busy: processing
2022-05-08 20:32:29,635 - Recv: T:53.52 /0.00 B:52.73 /60.00 @:0 B@:127
2022-05-08 20:32:30,545 - Recv: T:53.38 /0.00 B:52.83 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:31,544 - Recv: T:53.11 /0.00 B:53.05 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:31,551 - Recv: echo:busy: processing
2022-05-08 20:32:31,635 - Recv: T:53.05 /0.00 B:53.05 /60.00 @:0 B@:127
2022-05-08 20:32:32,545 - Recv: T:52.91 /0.00 B:53.20 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:33,544 - Recv: T:52.71 /0.00 B:53.41 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:33,553 - Recv: echo:busy: processing
2022-05-08 20:32:33,634 - Recv: T:52.67 /0.00 B:53.41 /60.00 @:0 B@:127
2022-05-08 20:32:34,544 - Recv: T:52.50 /0.00 B:53.64 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:35,546 - Recv: T:52.24 /0.00 B:53.85 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:35,548 - Recv: echo:busy: processing
2022-05-08 20:32:35,634 - Recv: T:52.24 /0.00 B:53.85 /60.00 @:0 B@:127
2022-05-08 20:32:36,544 - Recv: T:52.05 /0.00 B:54.08 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:37,545 - Recv: T:51.82 /0.00 B:54.19 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:37,551 - Recv: echo:busy: processing
2022-05-08 20:32:37,635 - Recv: T:51.82 /0.00 B:54.19 /60.00 @:0 B@:127
2022-05-08 20:32:38,544 - Recv: T:51.61 /0.00 B:54.40 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:39,545 - Recv: T:51.41 /0.00 B:54.55 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:39,552 - Recv: echo:busy: processing
2022-05-08 20:32:39,635 - Recv: T:51.38 /0.00 B:54.57 /60.00 @:0 B@:127
2022-05-08 20:32:40,544 - Recv: T:51.25 /0.00 B:54.77 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:41,545 - Recv: T:51.09 /0.00 B:54.94 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:41,552 - Recv: echo:busy: processing
2022-05-08 20:32:41,635 - Recv: T:51.05 /0.00 B:54.97 /60.00 @:0 B@:127
2022-05-08 20:32:42,545 - Recv: T:50.89 /0.00 B:55.14 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:43,545 - Recv: T:50.68 /0.00 B:55.27 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:43,551 - Recv: echo:busy: processing
2022-05-08 20:32:43,635 - Recv: T:50.68 /0.00 B:55.27 /60.00 @:0 B@:127
2022-05-08 20:32:44,545 - Recv: T:50.48 /0.00 B:55.42 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:45,545 - Recv: T:50.26 /0.00 B:55.61 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:45,552 - Recv: echo:busy: processing
2022-05-08 20:32:45,635 - Recv: T:50.26 /0.00 B:55.61 /60.00 @:0 B@:127
2022-05-08 20:32:45,795 - Changing monitoring state from "Printing" to "Cancelling"
2022-05-08 20:32:46,545 - Recv: T:50.17 /0.00 B:55.74 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:47,544 - Recv: T:49.97 /0.00 B:55.83 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:47,551 - Recv: echo:busy: processing
2022-05-08 20:32:47,635 - Recv: T:49.97 /0.00 B:55.83 /60.00 @:0 B@:127
2022-05-08 20:32:48,545 - Recv: T:49.75 /0.00 B:56.04 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:49,545 - Recv: T:49.51 /0.00 B:56.18 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:49,552 - Recv: echo:busy: processing
2022-05-08 20:32:49,635 - Recv: T:49.46 /0.00 B:56.20 /60.00 @:0 B@:127
2022-05-08 20:32:50,545 - Recv: T:49.31 /0.00 B:56.30 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:51,547 - Recv: T:49.16 /0.00 B:56.43 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:51,549 - Recv: echo:busy: processing
2022-05-08 20:32:51,635 - Recv: T:49.11 /0.00 B:56.46 /60.00 @:0 B@:127
2022-05-08 20:32:52,545 - Recv: T:48.96 /0.00 B:56.59 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:53,546 - Recv: T:48.68 /0.00 B:56.71 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:53,549 - Recv: echo:busy: processing
2022-05-08 20:32:53,636 - Recv: T:48.68 /0.00 B:56.71 /60.00 @:0 B@:127
2022-05-08 20:32:54,545 - Recv: T:48.59 /0.00 B:56.88 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:55,545 - Recv: T:48.39 /0.00 B:56.99 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:55,548 - Recv: echo:busy: processing
2022-05-08 20:32:55,636 - Recv: T:48.39 /0.00 B:56.99 /60.00 @:0 B@:127
2022-05-08 20:32:56,545 - Recv: T:48.16 /0.00 B:57.11 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:57,545 - Recv: T:48.01 /0.00 B:57.27 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:57,553 - Recv: echo:busy: processing
2022-05-08 20:32:57,636 - Recv: T:47.93 /0.00 B:57.27 /60.00 @:0 B@:127
2022-05-08 20:32:58,546 - Recv: T:47.89 /0.00 B:57.32 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:59,545 - Recv: T:47.66 /0.00 B:57.50 /60.00 @:0 B@:127 W:?
2022-05-08 20:32:59,554 - Recv: echo:busy: processing
2022-05-08 20:32:59,636 - Recv: T:47.62 /0.00 B:57.50 /60.00 @:0 B@:127
2022-05-08 20:33:00,546 - Recv: T:47.53 /0.00 B:57.63 /60.00 @:0 B@:127 W:?
2022-05-08 20:33:01,545 - Recv: T:47.34 /0.00 B:57.71 /60.00 @:0 B@:127 W:?
2022-05-08 20:33:01,553 - Recv: echo:busy: processing
2022-05-08 20:33:01,636 - Recv: T:47.32 /0.00 B:57.72 /60.00 @:0 B@:127
2022-05-08 20:33:02,546 - Recv: T:47.15 /0.00 B:57.86 /60.00 @:0 B@:127 W:?
2022-05-08 20:33:03,545 - Recv: T:46.91 /0.00 B:57.93 /60.00 @:0 B@:127 W:?
2022-05-08 20:33:03,553 - Recv: echo:busy: processing
2022-05-08 20:33:03,636 - Recv: T:46.91 /0.00 B:57.93 /60.00 @:0 B@:127
2022-05-08 20:33:04,546 - Recv: T:46.79 /0.00 B:58.13 /60.00 @:0 B@:127 W:?
2022-05-08 20:33:05,545 - Recv: T:46.58 /0.00 B:58.16 /60.00 @:0 B@:127 W:?
2022-05-08 20:33:05,548 - Recv: echo:busy: processing
2022-05-08 20:33:05,636 - Recv: T:46.58 /0.00 B:58.16 /60.00 @:0 B@:127
2022-05-08 20:33:06,546 - Recv: T:46.38 /0.00 B:58.32 /60.00 @:0 B@:127 W:?
2022-05-08 20:33:07,548 - Recv: T:46.30 /0.00 B:58.39 /60.00 @:0 B@:127 W:?
2022-05-08 20:33:07,550 - Recv: echo:busy: processing
2022-05-08 20:33:07,636 - Recv: T:46.25 /0.00 B:58.46 /60.00 @:0 B@:127
2022-05-08 20:33:08,545 - Recv: T:46.05 /0.00 B:58.54 /60.00 @:0 B@:127 W:?
2022-05-08 20:33:09,546 - Recv: T:45.97 /0.00 B:58.61 /60.00 @:0 B@:127 W:?
2022-05-08 20:33:09,554 - Recv: echo:busy: processing
2022-05-08 20:33:09,637 - Recv: T:45.89 /0.00 B:58.65 /60.00 @:0 B@:127
2022-05-08 20:33:10,545 - Recv: T:45.79 /0.00 B:58.75 /60.00 @:0 B@:127 W:?
2022-05-08 20:33:11,546 - Recv: T:45.63 /0.00 B:58.83 /60.00 @:0 B@:127 W:?
2022-05-08 20:33:11,555 - Recv: echo:busy: processing
2022-05-08 20:33:11,637 - Recv: T:45.63 /0.00 B:58.85 /60.00 @:0 B@:127
2022-05-08 20:33:12,545 - Recv: T:45.51 /0.00 B:58.96 /60.00 @:0 B@:127 W:?
2022-05-08 20:33:13,546 - Recv: T:45.26 /0.00 B:59.09 /60.00 @:0 B@:127 W:9
2022-05-08 20:33:13,552 - Recv: echo:busy: processing
2022-05-08 20:33:13,636 - Recv: T:45.26 /0.00 B:59.09 /60.00 @:0 B@:127
2022-05-08 20:33:14,546 - Recv: T:45.18 /0.00 B:59.17 /60.00 @:0 B@:127 W:8
2022-05-08 20:33:15,546 - Recv: T:45.00 /0.00 B:59.31 /60.00 @:0 B@:127 W:7
2022-05-08 20:33:15,553 - Recv: echo:busy: processing
2022-05-08 20:33:15,636 - Recv: T:45.00 /0.00 B:59.31 /60.00 @:0 B@:127
2022-05-08 20:33:16,546 - Recv: T:44.91 /0.00 B:59.39 /60.00 @:0 B@:127 W:6
2022-05-08 20:33:17,546 - Recv: T:44.69 /0.00 B:59.52 /60.00 @:0 B@:127 W:5
2022-05-08 20:33:17,548 - Recv: echo:busy: processing
2022-05-08 20:33:17,636 - Recv: T:44.67 /0.00 B:59.53 /60.00 @:0 B@:127
2022-05-08 20:33:18,546 - Recv: T:44.50 /0.00 B:59.58 /60.00 @:0 B@:127 W:4
2022-05-08 20:33:19,546 - Recv: T:44.39 /0.00 B:59.75 /60.00 @:0 B@:104 W:3
2022-05-08 20:33:19,553 - Recv: echo:busy: processing
2022-05-08 20:33:19,636 - Recv: T:44.36 /0.00 B:59.73 /60.00 @:0 B@:112
2022-05-08 20:33:20,546 - Recv: T:44.14 /0.00 B:59.80 /60.00 @:0 B@:106 W:2
2022-05-08 20:33:21,545 - Recv: T:44.12 /0.00 B:59.90 /60.00 @:0 B@:100 W:1
2022-05-08 20:33:21,553 - Recv: echo:busy: processing
2022-05-08 20:33:21,636 - Recv: T:44.04 /0.00 B:59.97 /60.00 @:0 B@:86
2022-05-08 20:33:22,546 - Recv: T:43.84 /0.00 B:60.01 /60.00 @:0 B@:90 W:0
2022-05-08 20:33:23,028 - Recv: ok
2022-05-08 20:33:23,030 - Send: N4 M10846
2022-05-08 20:33:23,033 - Recv: ok
2022-05-08 20:33:23,035 - Send: N5 M113 S2100
2022-05-08 20:33:23,039 - Recv: ok
2022-05-08 20:33:23,041 - Send: N6 M8425
2022-05-08 20:33:23,044 - Recv: ok
2022-05-08 20:33:23,046 - Send: N7 M104 T0 S038
2022-05-08 20:33:23,049 - Recv: ok
2022-05-08 20:33:23,051 - Send: N8 M140 S0109
2022-05-08 20:33:23,054 - Recv: ok
2022-05-08 20:33:23,056 - Send: N9 M106 S0*110
2022-05-08 20:33:23,058 - Recv: ok
2022-05-08 20:33:23,065 - Changing monitoring state from "Cancelling" to "Operational"
2022-05-08 20:33:23,636 - Recv: T:43.71 /0.00 B:60.06 /0.00 @:0 B@:0
2022-05-08 20:33:25,637 - Recv: T:43.49 /0.00 B:60.14 /0.00 @:0 B@:0
