I was using octoprint on a Pi3 for some month now.
It was working fine.
The attached display was running well as well and touch-ui was started automatically at startup.
Some weeks ago after a system update, touch-ui was not coming up anymore.
As you may know ... When a system is running without probs you loose all tipss and tricks and how tos
As I was using octoprint from my desktop pc as well, I did note take care about the small attached display.
Today I was feeling strong enough to fix it.
I was using this command to re-configure touch-ui:
sudo ~/TouchUI-autostart/helpers/install
It finished without any probs. After restarting the pi ... my octoprint is completely dead.
" The OctoPrint server is currently not running"
I have no idea how to aproach this issue?
Does anyone have any advice on what i could do best?
Cappy
Going to assume OctoPi,
Run the following and report back with the output. Do not exclude any information other than what may be considered sensitive:
ps auxww | grep octoprint
sudo systemctl status octoprint
cat /home/pi/.octoprint/logs/octoprint.log
thanks for ur response.
I do my very best to provide the requested information.
1st command returns:
pi 1928 0.0 0.0 4368 572 pts/0 S+ 17:22 0:00 grep --color=auto octoprint
2nds outbut is:
β octoprint.service - LSB: OctoPrint daemon
Loaded: loaded (/etc/init.d/octoprint; generated; vendor preset: enabled)
Active: active (exited) since Wed 2021-04-28 17:17:05 CEST; 24h ago
Docs: man:systemd-sysv-generator(8)
Process: 486 ExecStart=/etc/init.d/octoprint start (code=exited, status=0/SU
Tasks: 0 (limit: 4915)
CGroup: /system.slice/octoprint.service
Apr 28 17:17:05 octopi systemd[1]: Starting LSB: OctoPrint daemon...
Apr 28 17:17:05 octopi octoprint[486]: Starting OctoPrint Daemon: OctoPrint.
Apr 28 17:17:05 octopi systemd[1]: Started LSB: OctoPrint daemon.
the log cat is quite big ... I've attached it
1585912835462.remmina.log (27.5 KB)
I hope you can do more with it than me!?
Thanks for ur support.
Cappy
Not too much there. Lets try this
rm -f /home/pi/.octoprint/logs/*
source /home/pi/oprint/bin/activate
/home/pi/oprint/bin/python /home/pi/oprint/bin/octoprint serve --basedir /home/pi/.octoprint --safe
# check if web ui works. if not,
# open another ssh connection
Hey,
this was quick ...
... returns:
2021-04-29 17:45:38,929 - octoprint.startup - CRITICAL - Could not initialize settings manager: Error parsing the configuration file /home/pi/.octoprint/config.yaml, it is invalid YAML. The parser reported an error on line 3, column 15.
2021-04-29 17:45:38,930 - octoprint.startup - CRITICAL - There was a fatal error starting up OctoPrint.
Either you have a corrupt SD card or changes were made to the config file that it doesn't like.
Would need to see a copy in order to have an idea. You can grab it from /home/pi/.octoprint/config.yaml using something like FileZilla.
config.yaml (13.9 KB) SDcard was unning well for years now.
The issue accurs after an octoprint update.
touch-ui did not start anymore.
After updating or reinitializing touch.ui octoprint crashed ...
here comes config.yaml (just changed user names @259 and 300)
accessControl:
autologinLocal: true
autologinAs: cappy
autologinAs: cappy
localNetworks:
- 127.0.0.1/8
- ::1/128
salt: [REDACTED]
api:
Notice the autologinAs bit and what follows?
See Access Control β OctoPrint master documentation
Also notice the spacing is different there in general. yaml is picky about tab spacing. Either adjust to 4 space tabbing or 2.
I just found a config.backup at the .octoprint folder.
It was obviously created automatically before changing the touch-ui settings!?
Server is running now again.
Unfortunately touch-ui is still down
Hi again,
I still need some help to get touch-ui back?
My display (attached to the pi) alsways starts up at standard web interface!?
Mind uploading fresh logs?
Are you using a device with a touchscreen?
a fresh log is attached.
octoprint.log (239.7 KB)
My Display is a touch and attached to the Pi, yes.
It was running very well in the past.
Touch-UI was activated automatically.
Since an update, I can not date exactely it is coming up shoing the default web-interface of octopi.
There is no option to switch to touch-ui.
It is the same, if I connect via android-phone.
It was showing touch-UI as well ... currently only the default web-interface.
Does it make sense to uninstall the plugin and install again?
thanks 4 ur help
Cappy
This is what I did latest:
sudo apt-get upgrade
sudo service touchui stop
cd ~/TouchUI-autostart/ && git pull
sudo cp ~/TouchUI-autostart/touchui.init /etc/init.d/touchui
sudo chmod +x /etc/init.d/touchui
sudo systemctl daemon-reload
sudo service touchui start
sudo reboot
Did not bring up touch-ui
Any help ideas!?
Thx
Cappy
Good morning,
I have changed the headline because there are new findings.
Meanwhile OCTOPRINT is running again.
Curiously TOUCH UI is coming up on only a few divices.
I just purchased a new android tablet.
Using chrome to connect octoprint TOUCH UI is loaded automaticlly.
(Resolution is HD)
Wondering about that, I used chrome on my cell phone instead of MiBrowser ... TOUCH UI is comming up as well.
The pi-attached display does not show TOUCH UI and my MiBrowser does still not.
Is there a way to "reset" TOUCH UI to identify the pi-touch as mobile device again?
what should I do?
THX
Cappy
