Hi guys. I'm trying to install the MQTT plugin, on an offline OctoPrint instance. I downloaded the zip file and uploaded it, but it still tries to connect to the internet to do something. Is there a way to bypass this or do it locally and offline? I'm not in the position to grant it outside access at the moment. The error I'm getting:
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x75acc490>: Failed to establish a new connection: [Errno 101] Network is unreachable',)': /simple/paho-mqtt/
