So I cant install new plugins because the power limited mode (leistungsbegrenzt in german). I use octoprint for more than a year, and never had problems with plugins. How can I turn it off?
Heres a screenshot of the gui, you can see the warning in the yellow box (in german): https://i.imgur.com/xRP6myn.png
The best way to turn it off is to fix your power problem
But if you don't care you can just disable the raspberry support in the settings
Also take care that the printer board does not draw power from the Pi.
- Disconnect anything like USB lights or webcams that are plugged into your Pi
- Make sure that the power at the wall outlet is what it is supposed to be (plug it into a UPS)
- Make sure that the power adapter for the Pi has enough current (5V @ 2.5A)
- Make sure that the printer is plugged in, the power switch is on and it isn't sinking power from your Pi
Its not my PSU beeing not good enaugh but my Pi beeing too slow
Maybe there was something lost in translation because this doesn't make a lot of sense to me
Du sagst, dein Problem sei nicht das Netzteil, sondern, dass der Pi zu langsam ist?
Was meinst du damit?
