I have created two custom controls with a slider, as shown below
These controls work fine - no problem. However, I would like to add another button (for 'UNload) that uses the same temperature parameter from the slider as the 'Load Filament' button. Is there any way to do that?
TIA,
Frank
This one is a little bit harder to accomplish Frank, but I think might be possible using a javascript type command button and an inline javascript function to get a handle on the slider and pull it's value and then send the command using javascript instead of as a gcode. It would take some advanced js programming techniques which would require time to figure out.
Thanks for the info. Yeah, I figured it was in the "too hard" category, so I did four separate commands, each with their own slider.
Frank
I actually had this in my dev environment from when I was helping someone out. Just to give you an idea of how it could be done...this one doesn't send a command, but actually posts and API command to a plugin back-end. You would replace the OctoPrint.simpleApiCommand part with something like
OctoPrint.control.sendGcode($("#control-jog-custom > div > div > div > form > div > input[type=number]").val()});)
controls:
- children:
- additionalClasses: row-fluid
input:
- default: 100
parameter: feed_rate
slider:
max: 200
min: 0
step: 1
javascript: 'OctoPrint.simpleApiCommand("my_endpoint", "my_command", {"parameter":
$("#control-jog-custom > div > div > div > form > div > input[type=number]").val()});'
type: javascript
width: 3
layout: horizontal_grid
