when I click on the terminal tab it would be nice if the cursor was in the "command line" I invariably start typing and just get annoyed that I have to click in that bar
this is not a big deal just a convenience a nice to have
THANX
MITCH
If I had a son he would be a son of a Mitch
That would be a fairly easy plugin to write. All the heavy lifting would done in javascript.
Here you go. Use the URL below in Plugin Manager to install. Once installed when you switch to the Terminal tab it will automatically put focus on the command line.
https://github.com/jneilliii/OctoPrint-AutoTerminalInput/archive/master.zip
Thank you
this plugin does not show up in plugin manager. I was able to install from the url. how do I find out about other plugins that are not on the plugin manager or did you just create it for me. If so thanks so much (
THANX
MITCH
You drive up a dark alley to where jneiliii's car is parked, flash your headlights twice, hand him the envelope with money in it and he gives you the instructions. :laugh:
That's exactly what I did,.tips excepted here.
I just submitted it to the plugin repository, so it should show up at some point.
