Unable to get ExtraFile Info working in Octoprint
I am using Cura for my slicer and I have a Ender 3 Pro with an upgraded Silent board. I have added the ExtraFile Info plug in as well as the newest parser. In addition I have added the code in Cura (Start G-Code ) to pull the data I want and put it into the G-Code. When I open the gcode I can see the info has been added. So the data is there. I then added a Key and Label for one of the values in the gcode file in the ExtrafileInfo setting screen but still nothing shows up in octoprint.
Any suggestions??
Systeminfo bundle?
Sorry, Here you go
octoprint-systeminfo-20230308201701.zip (147.6 KB)
Here is the gcode as well
Hinge Center Finder B.gcode (1.2 MB)
Thank you for your assistance. I am quite new to this and need a bit of hand holding I think.
First this.
| *OctoPrint-SlicerSettingsParser (2.0.1) = /home/pi/oprint/lib/python3.9/site-packages/octoprint_SlicerSettingsParser
Your version is outdated:
As the parser does not work, the ExtraFileInfo does not get it's data.
Please avoid just powering off the Pi:
2023-03-07 20:23:40,112 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2023-03-07 20:23:37,674 - octoprint.startup - INFO - ******************************************************************************
2023-03-07 20:23:37,679 - octoprint.startup - INFO - Starting OctoPrint 1.8.7
2023-03-07 20:23:37,687 - octoprint.startup - INFO - ******************************************************************************
