now that's funny.
True but off-topic story: the very first plugin I published for Cura pretended to offer a way to switch off automatic slicing after making changes. All it did was place a white rectangle over the slicing progress bar so you would not see the slicing taking place. I got actual users telling me how much it sped up Cura. (Since then the plugin has been rewritten to actually do what it promised)
This
made me smile, but the next one,
made me laugh properly!
I started the upgrade-script on my Octopi 0.17 with Octoprint 1.4.12.
I confimed all prompts with enter, and entered my password when prompted in order to install python3-dev. Immediately after entering my password, the putty-session was terminated by the host.
Octoprint continued to work. I tried to restart the script, after entering my password for Python3-dev I got a cryptic message about wrong data in the stream.
Next step was to download and start the downgrade-script, which failed, claiming there is no data in the backup path.
At this point, my Octoprint installation does no longer work. The server is reachable via SSH, but Octoprint is not running.
When I ssh into the system, I see:
OctoPrint version : unknown
OctoPi version : 0.17.0
What is the best way to recover? I have an almost up-to-date backup of my Octoprint config, and I can backup my Klipper-config.
Best,
Detlev
Found the solution lol...just need to reboot the pi...and the 2nd instance is up again...
@Detlev_Rackow - could you open a separate topic, so I can discuss it through with you, and get a solution - it is fully possible to recover, since nothing of the old install gets deleted.
Easier than the comments of this post, where discussion gets confusing with many people.
Funny, I made a super half-hearted investigation to switch to Python 3 just last week. Saw it wasn't super easy and gave up. Then this post came out. Ran it on my most recent of three OctoPi 0.17 installs and it was super easy. No problems at all. Got the other two running right now but looks like I'll be able to switch everything to Python 3 with no problem at all. Thank you for making it so easy!
I followed the instructions but get this error
pi@octopi:~ sudo curl -L https://get.octoprint.org/upgrade.py --output upgrade.py
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 154 100 154 0 0 1062 0 --:--:-- --:--:-- --:--:-- 1062
100 39304 100 39304 0 0 92917 0 --:--:-- --:--:-- --:--:-- 92917
pi@octopi:~ sudo python3 upgrade.py
File "upgrade.py", line 1
<!DOCTYPE html>
SyntaxError: invalid syntax
Can anyone help?
If you enter the command(s) you typed as Preformatted text (</> icon above), we might be able to see if there was a typo. Using PuTTY you can cut the command out of this thread and paste it in the SSH terminal window using right-click.
@uppermill - wrong URL, check it.
Should be https://get.octoprint.org/py3/upgrade.py
edit as @b-morgan says, just copy and paste it into an SSH window to get it exactly right
@cmh Thanks for the feedback
The script has been around in a sort of 'testing' state until now, I first wrote it back in June. There's a couple of forum posts etc. etc. but anyway great to hear it worked well for you.
Worked great! Thanks!!
Thanks for the fast responses. I updated the URL and everything has now completed successfully.
@Charlie_Powell Sweet, nice and easy, looks good. Pi4, 0.12-0.15 (Can't remember where this started) original install with about 10 plugins and standard updates/upgrades since. Took less than 5 minutes to run and looks to be working fine. Thanks for the sweet script!
All went well with the base install, It initially screwed my GPX plugin. I couldn't install the plugin from the plugin manager so installed it manually. Re-created the gpx.ini file and away I went.
I'm running OctoPrint 1.4.2, OctoPi 0.18.0.
Thank you
Yeah, that bug of not being able to install should be fixed in the next release of OctoPrint.
If I were a newbie to Linux then I would have given up, So a message to anyone who is new and cannot follow logs and diagnose issues in Linux I would avoid the upgrade if you have tons of plugins.
But thank you to whoever created this script. I'm guessing @jneilliii?
Nope not me, @Charlie_Powell all the way. He's new on the scene and has quickly become a plugin author (WS281x LED Status) as well as a huge help in discord, here in the forum, and assisting Gina with issue/bug maintenance triage and fixing.
@Charlie_Powell Sorry, that is not correct. Klipper itself is written in Python. Look at this folder:
klippy is the core of Klipper's functionality. Klipper is still based on Python 2.7.There is even a branch of Klipper where work is being done on porting to Python 3, but it's stale. "Master" gets updates on a daily basis, the branch for Python 3 is three months old.
Octoklipper is simply a regular plugin for Octoprint, written by another guy.
It is not necessary for interoperability, but makes configuration of Klipper available through Octoprint which is pretty nice.
The plugin has a fork for Python 3 which seems to work pretty well.
Klipper itself seems quite stuck in 2.7. The maintainers are very active in developing functional improvements, but questions about Python 3 get canned answer. Since it's nothing I need to expose to the internet, that's sort of ok - as long as it stays compatible with my Octopi.
