Just need to wait for an update to Filament Manager
Not running it as root solved my issue.
@Niamh - Filament manager got taken over by @OllisGit yesterday (maybe the day before), so you're in luck!
Release notes
https://github.com/OllisGit/OctoPrint-FilamentManager/releases/tag/1.6.0
You should get a notice that it has been transferred, but you need to reinstall as the updates are looking in the wrong place. See plugin notices if you don't get it, at the bottom Plugin notices
OK, so just uninstall the existing filament manager ten install the new one?
If you go to Settings > Plugin Manger > Get More then find 'Filament Manager' there should be a reinstall button beside it
you may need to check it is not filtered on installed plugins only.
Or if you can't find that, uninstall without cleaning data (you'll lose all your config) then install it again.
I am running .17. I rcvd this error:
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/dpkg/status
E: The package lists or status file could not be parsed or opened.
ERROR: failed to update package list
Please try manually
Cleaning up...
Fatal error: Exiting
Try updating the package list manually, with sudo apt-get update, that seems an issue with your OctoPi installation - nothing I can do about that.
Also check it is connected to the internet, then if you still need help solving the problem please open a separate topic in 'Get help'.
Definitely connected to the internet
pi@octopi:~ $ sudo apt-get update
[sudo] password for pi:
Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Fetched 15.0 kB in 1s (13.8 kB/s)
Reading package lists... Error!
Thanks for the upgrade script.
I found that I had 3 plugins that used python V2, so deleted them first.
The upgrade script worked flawlessly
I now just have to wait for the plugin owners to upgrade their pplugins to V3
cheers
ian
I wish these 4 plugins would be upgraded to python 3
- LayerDisplay (0.4.3) from Matt Thompson
- OctoKlipper (0.2.5) from Martin Muehlhaeuser
- Terminal Commands (0.1.6) from ieatacid
- Webcam Tab (0.1.2) from Sven Lohrmann
most importantly the Octoklipper plugin.
EDIT: Whoahh, I just realised that after removing the Octoklipper 0.2.5 plugin I could install the 0.3.1 version from Alice Weigt, which is python 3 compatible!!!
Hope that helps anyone
EDIT 2: Success: OctoPrint 1.4.2 Python 3.7.3 OctoPi 0.17.0 (deactivated the three plugins before upgrading with the script).
THANKS
Yeah, the Klipper plugin it was adopted officially yesterday. Go and let the plugin authors know that you want Python 3 compatibility, for the others, at some point OctoPrint will drop Py2 support so they need to be made compatible.
On every plugin there is at least one "python 3 upgrade" issue.
my Terminal Commands Extended plugin is Py3 compatible...
***Bed Visualizer is gone ***
The Python upgrade worked fine, printing seems to work ( just testing
Only I miss the Bed Visualizer, even after installing the plugin again, it does not appear
There should have been a link when installing that plugin that extra action is required. And @jneilliii posted that link in the comments, previously.
that worked perfect !!
Many thx
21:47 root@pine64 /opt/octoprint# python3 upgrade.py
This script will only run on python 3.6+
Run using 'python3 upgrade.py'
21:49 root@pine64 /opt/octoprint# python3 --version
Python 3.5.3
Yeah. This should/could have been noted somewhere.
And now (i remember why i hate the python ecosystem - everything related to maintenance of application made with python is just a time sink) ...
Path: /opt/octoprint/venv
Path valid
Config directory: /home/octoprint/.octoprint
Config directory valid
To do the install, we need the service stop and start commands. (Leave blank if you don't have a service set up)
Stop command: systemctl stop octoprint
Start command: systemctl start octoprint
Getting OctoPrint version...
File "/usr/lib/python2.7/runpy.py", line 163, in _run_module_as_main
mod_name, _Error)
File "/usr/lib/python2.7/runpy.py", line 111, in _get_module_details
__import__(mod_name) # Do not catch exceptions initializing package
File "/opt/octoprint/venv/local/lib/python2.7/site-packages/octoprint/__init__.py", line 7, in <module>
import logging as log
File "/usr/lib/python2.7/logging/__init__.py", line 26, in <module>
import sys, os, time, cStringIO, traceback, warnings, weakref, collections
File "/usr/lib/python2.7/weakref.py", line 14, in <module>
from _weakref import (
ImportError: cannot import name _remove_dead_weakref
Failed to find OctoPrint install
If you are not on OctoPi, please check you entered the correct path to your virtual environment
And here i have no idea why my paths are not the proper ones.
