You should get a notice that it has been transferred, but you need to reinstall as the updates are looking in the wrong place. See plugin notices if you don't get it, at the bottom Plugin notices
If you go to Settings > Plugin Manger > Get More then find 'Filament Manager' there should be a reinstall button beside it you may need to check it is not filtered on installed plugins only.
Or if you can't find that, uninstall without cleaning data (you'll lose all your config) then install it again.
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/dpkg/status
E: The package lists or status file could not be parsed or opened.
ERROR: failed to update package list
Please try manually
Definitely connected to the internet
pi@octopi:~ $ sudo apt-get update
[sudo] password for pi:
Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Fetched 15.0 kB in 1s (13.8 kB/s)
Reading package lists... Error!
I wish these 4 plugins would be upgraded to python 3
LayerDisplay (0.4.3) from Matt Thompson
OctoKlipper (0.2.5) from Martin Muehlhaeuser
Terminal Commands (0.1.6) from ieatacid
Webcam Tab (0.1.2) from Sven Lohrmann
most importantly the Octoklipper plugin.
EDIT: Whoahh, I just realised that after removing the Octoklipper 0.2.5 plugin I could install the 0.3.1 version from Alice Weigt, which is python 3 compatible!!!
Hope that helps anyone
EDIT 2: Success: OctoPrint 1.4.2 Python 3.7.3 OctoPi 0.17.0 (deactivated the three plugins before upgrading with the script).
THANKS
Yeah, the Klipper plugin it was adopted officially yesterday. Go and let the plugin authors know that you want Python 3 compatibility, for the others, at some point OctoPrint will drop Py2 support so they need to be made compatible.
And now (i remember why i hate the python ecosystem - everything related to maintenance of application made with python is just a time sink) ...
Path: /opt/octoprint/venv
Path valid
Config directory: /home/octoprint/.octoprint
Config directory valid
To do the install, we need the service stop and start commands. (Leave blank if you don't have a service set up)
Stop command: systemctl stop octoprint
Start command: systemctl start octoprint
Getting OctoPrint version...
File "/usr/lib/python2.7/runpy.py", line 163, in _run_module_as_main
mod_name, _Error)
File "/usr/lib/python2.7/runpy.py", line 111, in _get_module_details
__import__(mod_name) # Do not catch exceptions initializing package
File "/opt/octoprint/venv/local/lib/python2.7/site-packages/octoprint/__init__.py", line 7, in <module>
import logging as log
File "/usr/lib/python2.7/logging/__init__.py", line 26, in <module>
import sys, os, time, cStringIO, traceback, warnings, weakref, collections
File "/usr/lib/python2.7/weakref.py", line 14, in <module>
from _weakref import (
ImportError: cannot import name _remove_dead_weakref
Failed to find OctoPrint install
If you are not on OctoPi, please check you entered the correct path to your virtual environment
And here i have no idea why my paths are not the proper ones.
That looks like an issue in your installation. Script's trying to run octoprint --version to find it, and that failed. Not sure what to suggest, does OctoPrint run properly normally?
