I can't seem to get to Octoprint from the js-client when uploading a file. It works just fine for other commands like reading printhead temperature.
I am trying:
var octoClient = new OctoPrintClient({
baseurl: "http://pi.local",
apikey: "key"
octoClient.files.upload("local", robot.selected_file.content, {
"filename": robot.selected_file.name,
"select": true,
"print": true
}).done(function(response) {
console.log(response);
Where robot.selected_file.content is the raw gcode file.
It does not succeed. I get:
angular.js:15567 Error: Syntax error, unrecognized expression: M155 S5
... // The "unrecognized expression" is my gcode file.
G1 X65.126 Y-125.55
jquery.js:1541)
at Sizzle.tokenize (jquery.js:2193)
at Sizzle.select (jquery.js:2620)
at Function.Sizzle [as find] (jquery.js:845)
at jQuery.fn.init.find (jquery.js:2873)
at new jQuery.fn.init (jquery.js:2983)
at jQuery (jquery.js:139)
at OctoPrintClient.upload (base.js:214)
at OctoPrintFilesClient.upload (files.js:129)
at ChildScope.scope.print (bot.js:74)
I tried a few things to resolve, but no luck yet. I'm on jQuery 3.3.1 and AngularJS.
I copied the octoprint js files directly from github, as I am communicating with multiple printers, so I don't want to pull the js files from each individual printer as I switch printers.
EDIT
I tweaked the octoprint base.js a bit to allow my raw gcode file to be sent, which fixed the above error. I changed:
if (typeof file == "string") {
fileData = $(file)[0].files[0];
to:
fileData = file;
This allowed the files to be sent, but I am getting a CORS error now. Not because I didn't enable CORS. CORS is enabled and I have confirmed by seeing the header returned from printer.getFullState().
I think I get the CORS error because there is still some issue in trying to send a raw gcode file to http://pi.local/api/files/
I get:
Access to XMLHttpRequest at 'http://south.local/api/files/' from origin 'http://localhost:9900' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource.
base.js:283 POST http://south.local/api/files/ net::ERR_FAILED
OctoPrintClient.upload @ base.js:283
OctoPrintFilesClient.upload @ files.js:129
scope.print @ bot.js:78
fn @ VM7620:4
callback @ angular.js:28951
$eval @ angular.js:19393
$apply @ angular.js:19492
(anonymous) @ angular.js:28955
dispatch @ jquery.js:5183
elemData.handle @ jquery.js:4991
When I view the request, it shows the form data is properly sending file, filename, select, and print form data attributes properly.
