I'm using Octoprint 1.3.6 with a Flashforge Creator Pro 2016, Sailfish 7.8 on a Raspberry 3.
All seems to work until now. The files list from the SD is shown, the temperature curves are draw and updated.
The only exception uploading a file to the SD card.
The upload starts, shows the progress bar increasing but oat the end an error is thrown:
Send: M28 /DoorLockForPadLockMovingPa.x3g
Unexpected error while writing to serial port: IOError: 'Command not supported or recognized' @ comm.py:_do_send_without_checksum:2499
Changing monitoring state from 'Operational' to 'Offline: IOError: 'Command not supported or recognized'@comm.py:_do_send_without_checksum:2499'
The entries written to octoprint.log are:
2018-03-29 13:21:47,350 - octoprint.plugins.GPX - INFO - Connecting through x3g.
2018-03-29 13:21:47,359 - octoprint.plugins.GPX - INFO - GPXPrinter created, port: /dev/ttyACM0, baudrate: 115200
2018-03-29 13:21:51,432 - octoprint.plugins.GPX - INFO - gpx.connect succeeded
2018-03-29 13:21:51,452 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-03-29 13:21:51,492 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-03-29 13:21:53,543 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-03-29 13:21:53,560 - octoprint.util.comm - INFO - Printer reports firmware name "Sailfish"
2018-03-29 13:22:31,290 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-03-29 13:22:31,324 - octoprint.util.comm - ERROR - Unexpected error while writing to serial port
File "/home/pi/oprint/local/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/util/comm.py", line 2499, in _do_send_without_checksum
result = self._serial.write(to_send)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_GPX/gpxprinter.py", line 131, in write
self._append(gpx.write("%s" % data))
IOError: Command not supported or recognized
2018-03-29 13:23:38,649 - octoprint.plugins.GPX - INFO - Connecting through x3g.
2018-03-29 13:23:38,651 - octoprint.plugins.GPX - INFO - GPXPrinter created, port: /dev/ttyACM0, baudrate: 115200
2018-03-29 13:23:42,686 - octoprint.plugins.GPX - INFO - gpx.connect succeeded
2018-03-29 13:23:42,706 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
Can anyone confirm that this works on an FFCP works with Sailfish 7.8?
TIA,
Gerhard
