USB Raspberry Pi Isolator
Hi folks, this is the smallest simplest project I have done in a while but it may help people. I have designed a 3-D printed template for a piece of plastic that can be used to isolate the 5V on the RPi USB from the 3D printer. It makes it less likely the Pi will get damaged or suffer from brownouts.
USB 5V Isolator
Rob
Good job :slight_smile:
Alternatively you could also use this design:
