For the record, I did test a bullseye nightly with the aforementioned /boot/config.txt against an RPi3 with an attached RPiCam, successfully.
With the bullseye image from the Pi Imager on a Pi 3 with camera_auto_detect=0 I tried:
./mjpg_streamer -i "./input_uvc.so -fps 5" -o "./output_http.so"
and got this:
i: Frames Per Second.: 5
i: Format............: JPEG
ERROR opening V4L interface: No such file or directory
i: init_VideoIn failed
I use first bullseye build of raspberry pi os (released in November or December)
Yes, rebooted after enabling legacy stack in rasp-config and another reboot after adding camera_auto_detect=0 to confing
Previously did not get you right, read rebuild as reboot.
Finally, once I rebuild mjpg-streamer, it start working.
Thank you so much!
