The bump of core from 200 to 250 MHz once webcamd is started got me thinking... So set that as the target core frequency and VOILA:
I don't see a bump anymore
root@enderpi:~# bcmstat.sh
Config: v0.5.5, args "MCxgpd1 Tye", priority maximum (-20)
Board: 4 x ARMv7 cores available, ondemand governor (Pi3 Model B+ rev 1.3, BCM2837 SoC with 1GB RAM by Sony UK)
Memory: 1024MB (split 896MB ARM, 128MB GPU)
HW Block: | ARM | Core | H264 | SDRAM |
Min Freq: | 600MHz | 250MHz | 0MHz | 450MHz |
Max Freq: | 1200MHz | 250MHz | 250MHz | 450MHz |
Voltages: | -4, 1.1563V | +2, 1.2500V |
Other: temp_limit=85
Firmware: Jan 27 2021 22:27:56, version 99d9a48302e4553cff3688692bb7e9ac760a03fa (clean) (release) (start_x)
Codecs: H264 H263 MPG4 VP8 VP6 VORB THRA MJPG FLAC PCM
Booted: Wed Mar 3 13:59:41 2021
Time UFT Vcore ARM Core H264 Core Temp (Max) IRQ/s RX B/s TX B/s %user %nice %sys %idle %iowt %irq %s/irq %total cpu0 cpu1 cpu2 cpu3 GPUMem Free MemFreeKB / %used
14:02:37 1.1563 1200Mhz 250Mhz 0Mhz 49.39C (49.93C) 4,021 0 0 6.33 0.00 22.16 69.66 0.00 0.00 3.17 30.34 36.68 36.68 24.01 11.35 90M ( 83%) 794,764 / 11.1%
14:02:38 1.1000 600Mhz 250Mhz 0Mhz 48.85C (49.93C) 1,903 0 0 3.20 0.00 4.80 90.59 0.00 0.00 0.00 9.41 9.41 6.67 9.41 13.99 90M ( 83%) 794,808 / 11.1%
14:02:39 1.1000 600Mhz 250Mhz 0Mhz 49.39C (49.93C) 2,025 0 0 4.09 0.00 6.82 87.54 0.00 0.00 0.00 12.46 17.24 12.69 10.87 8.14 90M ( 83%) 794,852 / 11.1%
14:02:53 1.1563 700Mhz 250Mhz 0Mhz 48.31C (49.93C) 1,953 0 0 2.77 0.00 8.54 87.93 0.00 0.00 0.00 12.07 18.77 9.53 11.38 8.61 90M ( 83%) 795,112 / 11.0%
14:02:54 1.1563 1200Mhz 250Mhz 0Mhz 48.85C (49.93C) 2,160 0 0 4.40 0.00 6.03 87.36 0.00 0.00 0.23 12.64 18.43 12.87 11.94 7.31 90M ( 83%) 794,556 / 11.1%
14:02:55 1.1563 700Mhz 250Mhz 0Mhz 49.39C (49.93C) 4,138 0 0 5.48 0.00 6.85 85.39 0.00 0.00 0.46 14.61 19.64 13.24 15.07 10.50 90M ( 83%) 793,904 / 11.2%
14:02:56 1.1563 800Mhz 250Mhz 0Mhz 49.39C (49.93C) 4,463 0 0 6.84 0.00 8.20 82.27 0.00 0.00 0.91 17.73 17.96 23.43 17.96 12.49 90M ( 83%) 794,500 / 11.1%
14:03:04 1.1563 700Mhz 250Mhz 0Mhz 49.39C (49.93C) 4,545 0 0 6.15 0.00 10.93 81.51 0.00 0.00 0.23 18.49 19.86 24.41 17.13 13.48 90M ( 83%) 794,652 / 11.1%
14:03:05 1.1563 1200Mhz 250Mhz 0Mhz 49.93C (49.93C) 4,119 0 0 5.84 0.00 11.92 80.63 0.00 0.00 1.64 19.37 22.41 26.15 14.00 14.93 90M ( 83%) 794,112 / 11.1%
14:03:06 1.1563 700Mhz 250Mhz 0Mhz 49.93C (49.93C) 4,710 0 0 6.68 0.00 8.75 79.00 0.00 0.00 1.15 21.00 18.93 27.22 15.25 23.54 90M ( 83%) 793,988 / 11.1%
14:03:07 1.1563 1200Mhz 250Mhz 0Mhz 49.39C (49.93C) 3,809 0 0 6.98 0.00 8.38 78.92 0.00 0.00 1.63 21.08 24.57 30.15 12.46 15.25 90M ( 83%) 794,112 / 11.1%
14:03:08 1.1563 700Mhz 250Mhz 0Mhz 50.46C (50.46C) 3,866 0 0 5.44 0.00 4.98 85.41 0.00 0.00 1.13 14.59 14.82 25.69 10.29 8.47 90M ( 83%) 793,292 / 11.2%
Peak Values: IRQ: 4806, RX: 0, TX: 0, UVOLT: 0, FCAPPED: 0, THROTTLE: 0
root@enderpi:~#
