Webpage too narrow (Solved by Roland)
The webpage for octoprint is too narrow and the banner on top due to excess information that I want to see is now more than one line because the logo now has its own line
Resizing screen, looked online to see if I could change it in themes or somethign
OctoPi 15
Screenshot link - Screenshot
Have you tried removing the temperature settings that you have ? Failing that, reduce the font size to allow more width space.
You can use the plugin Themeify to change the width of the webpage
under Advanced options Custom style i added:
I'd be curious to see how it looked in another web browser, or another computer
Roland, my man! That is exactly what I was looking for, I knew I should be able to do it in themeify but I don't know all the proper .###### commands to use. THANKS SO MUCH!
Spyder, I was getting the same on all my computers and browsers, however now that I have changed it, it is perfect. If you want to see it in real time PM me and I will send you ip:port.
I had seen this before and it took me forever to find it again. THX it works like a charm!!!! LUV it!
Hey guys. This was terrific. I did this to get more use from my screen and liked it. Now another question. Can I adjust the terminal height? It uses only half of the screen. Tks.
44%20AM
#term .terminal #terminal-output, #term .terminal #terminal-output-lowfi
That was great! Thanks!
