My webcam stream is visible in Control and the Octolapse Webcam Setup tests check out. When, however, I try to edit Custom Image Preferences, I get the following error:
Unable To Enable Custom Preferencesunknown-server-type: An unknown webcam server type 'Werkzeug/0.15.6 Python/2.7.13' is being used for the 'piCam' camera profile. Currently only MJPEGStreamer is supported. Unable to apply custom image preferences.
I'm suspicious this may be Octoprint Anywhere's doing because when I disable OA, I no longer see anything from the webcam; the webcam is only ever operational with Octoprint Anywhere installed and active.
How can I specify my webcam server type so that I can get the best Octolapses? Thanks.
@mikejkelley, I believe Octoprint Anywhere uses its own built-in server, which does not support the mjpegstreamer control.htm page, unfortunately. If you want to use the custom image preferences, you'll need to use mjpgstreamer.
Have you found the issue ? i have exactly the same error that you had. Im looking for some help to get my logitec c270 to work with octolapse. Thanks !
The issue is getting the custom image preferences to work while using Octoprint Anywhere or the Spaghetti Detective. Octolapse itself (taking a timelapse) should work just fine. What issue are you seeing exactly?
Im getting the same error message in octolapse when i try to enable custom image preferences . Unable to reach the control page manualy. Unable To Enable Custom Preferencesunknown-server-type: An unknown webcam server type 'Werkzeug/0.15.6 Python/2.7.13' is being used for the 'c270cam' camera profile. Currently only MJPEGStreamer is supported
I got Octolaps to work with the ability to edit image preferences yesterday, but today I get this error message. I tried to uninstall The Spagetti Detective. If I uninstall TSD I have no image at all. I am using Raspi V2 cam. What could this problem be due to?
