Hello @Rett_Genatempo!
When you run a G29, the firmware usually takes the results on its own to optimize the first layer(s) prints.
Ewald is correct, the plugin doesn't do anything to compensate for the probed mesh, it literally just displays what the firmware sees and reports from the probe points.
Thank you! Is there any way to just use the data in my Gcodes instead of it auto-leveling the bed before every print?
Do you have a removable print bed?
If yes, then it's better to auto-level before every print.
Also, this 16 points are faster measured then an entire print will take.
You could modify your firmware so you do a levelling once in a while.
Bed levelling is so much hardware related, it always should belong to the printer, not the slicer.
I have the standard print bed with a removable plate magnetically held in place.
Darrell
Thanks for your assistance!
