Hello,
i would like to run some php-script files on my octopi (raspi 3) at command-line.
Why i would like to to so:
I have an unsused DECT-switch-connector (AVM DECT 200).
I plan to use this device to switch on/off my Ender 5 before / after printing. AVM (my Web-Router (is always on)) had a web-Interface that can switch (and some other stuff) this devices. So i have to start some php-scripts to do switching the Ender on/off.
I want to run this scripts manually via menu or (later) by event from octoprint. But before this could run, it is nessesary to install php(5) and php-mbstring on raspberry.
Afaik, this packages could be installed by
apt-get install php php-mbsting
but i got an error. The source could not be found.
Perhaps i have to change the repository-source but what´s about octopi-sources?
I don´t want to loose the update-function by octopi / octoprint.
Thanks Horex1200
