Yes of course! I didn't know how to get those details, but your link helped! I copied the part after the print is finished. Reading this myself, I see that something went wrong in setting up both the Dropbox connection and the YouTube connection. I'll be looking into each of them myself too. I did follow the dedicated pages that showed a step-by-step process of how to set them up, but I guess I still did something wrong
2022-01-27 15:53:27,020 - octoprint.util.comm - INFO - Finished in 1982.147 s.
2022-01-27 15:53:27,021 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Finishing"
2022-01-27 15:53:27,046 - octoprint.printer.standard.job - INFO - Print job done - origin: local, path: Paste_Printing/January 2022/January 27, 2022/CubeV2_Test2_Flow95.gcode, owner: Gutharic
2022-01-27 15:53:27,177 - octoprint.util.comm - INFO - Changing monitoring state from "Finishing" to "Operational"
2022-01-27 15:53:27,268 - octoprint.plugins.excluderegion - INFO - Printing stopped: event=PrintDone
2022-01-27 15:53:27,271 - octoprint.plugins.octoeverywhere - INFO - RepeatTimer thread exit
2022-01-27 15:53:27,535 - octoprint.plugins.octoeverywhere - INFO - NotificationsHandler successfully sent 'done'; ETA: 0
2022-01-27 15:55:15,173 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2022-01-27 15:57:50,605 - backoff - INFO - Backing off wait_for_auth_token(...) for 367.9s (None)
2022-01-27 15:59:29,082 - octoprint.plugins.dashboard - INFO - GcodePreProcessor started processing.
2022-01-27 15:59:29,125 - octoprint.filemanager.analysis - INFO - Starting analysis of local:Paste_Printing/January 2022/January 27, 2022/CubeV2_Test3_Flow90.gcode
2022-01-27 15:59:29,247 - octoprint.plugins.dashboard - INFO - GcodePreProcessor found layers: 10
2022-01-27 15:59:29,248 - octoprint.plugins.dashboard - INFO - GcodePreProcessor found filament changes: 0
2022-01-27 15:59:29,248 - octoprint.plugins.dashboard - INFO - GcodePreProcessor saving layer count in file metadata
2022-01-27 15:59:29,789 - octoprint.filemanager.analysis - INFO - Analysis of entry local:Paste_Printing/January 2022/January 27, 2022/CubeV2_Test3_Flow90.gcode finished, needed 0.66s
2022-01-27 15:59:42,356 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: Paste_Printing/January 2022/January 27, 2022/CubeV2_Test3_Flow90.gcode, owner: Gutharic, user: Gutharic
2022-01-27 15:59:42,361 - octoprint.plugins.excluderegion - INFO - File selected, resetting internal state
2022-01-27 15:59:42,375 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2022-01-27 15:59:42,378 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: Paste_Printing/January 2022/January 27, 2022/CubeV2_Test3_Flow90.gcode, owner: Gutharic, user: Gutharic
2022-01-27 15:59:42,404 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-01-27 15:59:42,407 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2022-01-27 15:59:42,417 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2022-01-27 15:59:42,443 - octoprint.plugins.excluderegion - INFO - Printing started
2022-01-27 15:59:42,738 - octoprint.plugins.octoeverywhere - INFO - NotificationsHandler successfully sent 'started'; ETA: 1959
2022-01-27 16:00:14,739 - octoprint.plugins.dropbox_timelapse - INFO - Uploading CubeV2_Test2_Flow95_20220127152024.mp4 to Dropbox...
2022-01-27 16:00:20,166 - octoprint.plugin - ERROR - Error while calling plugin dropbox_timelapse
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugin/__init__.py", line 271, in call_plugin
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/__init__.py", line 1737, in wrapper
return f(*args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_dropbox_timelapse/__init__.py", line 115, in on_event
if self.upload_timelapse(file_path):
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_dropbox_timelapse/__init__.py", line 159, in upload_timelapse
db.files_upload(f.read(), '/'+file_name, mode=WriteMode('overwrite'))
File "/home/pi/oprint/lib/python3.7/site-packages/dropbox/base.py", line 2865, in files_upload
f,
File "/home/pi/oprint/lib/python3.7/site-packages/dropbox/dropbox_client.py", line 329, in request
timeout=timeout)
File "/home/pi/oprint/lib/python3.7/site-packages/dropbox/dropbox_client.py", line 485, in request_json_string_with_retry
timeout=timeout)
File "/home/pi/oprint/lib/python3.7/site-packages/dropbox/dropbox_client.py", line 604, in request_json_string
raise BadInputError(request_id, r.text)
dropbox.exceptions.BadInputError: BadInputError('99362d69e42d4e8d9f4eeddddb8f074d', 'Error in call to API function "files/upload": Your app is not permitted to access this endpoint because it does not have the required scope \'files.content.write\'. The owner of the app can enable the scope for the app using the Permissions tab on the App Console.')
2022-01-27 16:00:20,183 - octoprint.plugins.youtube_timelapse - INFO - No Google credentials Defined! Cannot Upload Timelapse CubeV2_Test2_Flow95_20220127152024.mp4!
