My Prusa i3 MK3 stops and asks for change of filament - eventhough I only has one material in the gcode.
I am printing the SAME gcode file on the printer from the SD Card - without the use of Octoprint. This works perfectly.
I'm using a Raspbarry PI 3B+ which - before 1.3.10 update - worked perfect for me.
ONLY change to introduce the problem was the update to 1.3.10.
Now using slic3r 1.41.2+
