Can't udpate to latest 1.5.3 version
Checking my free space
enlarging filesystem to whole sdcard space
nope
don't think so, will have to learn how to run it.
Complete Logs
octoprint.log (154.9 KB)
serial.log (198 Bytes)
Raspi 3B+
16 Gb SDCard
connected to ethernet / CPL
Ender 3 @115200
TP-link HS110
16 ring neopixel
SO.
the question is : what should I do for liberate free space that the system can auto update ?
Tofoillote:
Have you tried running in safe mode ?
nope
Reboot the pi and try it in safe mode just to be sure
click on the words safe mode for further instructions
5ft24
February 7, 2021, 5:15am
3
There should be plenty of room there for the update. It shows your root filesystem has 12G free
If you haven't already, reboot the pi and then try.
So here are my good results.
restarted in safe mode tell me :
the clue is
system temporary files (/tmp): 149.3MB free
that is not all wrong due to my special configuration of system files. in fact I have mount /tmp as a ramdisk in /etc/fstab !
and this is the problem : not enough free ram for update.
so deactivating this mount, and rebooting octopi in normal mode seem ok.
updating octoprint then plug ins
Ok
now I can go check for another help about my starting time.
5ft24
February 11, 2021, 9:19pm
5
If you want a temp ram disk, don't call it /tmp. /tmp is a system generated mountpoint, and it adjusts the size as needed. If you want a ram disk mounted, call it /temp and you'll be fine
I use to ramdisk the /tmp in order to speed up mjpg-streamer at streming and encoding webcam videos. its an octolapse recomendation. the whole system should have benefit.
it also make some sdcard use economy, increasing its life.
Great! Please us this:
All topics you create in this category can be marked as "Solved" by clicking the little icon under the post that contains the solution:
[image]
Please make heavy use of it. Marking a topic as solved allows others to quickly see that a solution has been found and also displays the solution prominently right in the start post so that others with the same problem may find it easier, without having to scan through the whole thread.
Thank you!
instead of changing the title.
