upoaded .gcode to printer and the progress bar in web browser rapidly goes to 100% then back to null within a second. Heaters are not activated. Connection shows "operational?" Please help I can't live without OctopPrint. This all started with the latest version of OctoPi.
EDIT: gcode viewer tab is blank now that I am printing from the SD card.
@Printinator The template is there for a reason. It requests info we need to help you solve the problem. A problem which might be unique to your setup and won't magically disappear with a new version, if you do not collaborate with use here and share what's requested. Do you want your problem solved? Then fill in the template, test safe mode, share a system info bundle, be prepared to answer additional questions. Don't want your problem solved? Fine, but then don't waste our time either please.
