1.9.3 won't connect to printer on ttyACM0
I have a CTC Bizer that connects to my RPi on /dev/ttyACM0. This printer was working fine with an older version of Octoprint (1.3.9). I was forced to upgrade when my old SD card with the image crashed and I rebuilt the OctoPi/Octoprint sw.
I have an Ender 3 Pro that connects on /dev/ttyUSB0 and that's working fine.
The printer can be seen by the RPi.
sudo lsusb -v
Bus 001 Device 007: ID 23c1:d314 MakerBot Industries The Replicator
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 2 Communications
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x23c1
idProduct 0xd314
bcdDevice 0.01
iManufacturer 1 MakerBot Industries
iProduct 2 The Replicator
iSerial 220 75533353637351C0F182
bNumConfigurations 1
From dmesg:
[Wed Oct 18 15:22:15 2023] cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
[Wed Oct 18 15:22:15 2023] usbcore: registered new interface driver cdc_acm
[Wed Oct 18 15:22:15 2023] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[Sat Oct 21 11:53:05 2023] cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
ls -l /dev/octo_CTC
lrwxrwxrwx 1 root root 7 Oct 21 11:53 /dev/octo_CTC -> ttyACM0
From the serial.log:
2023-10-21 18:28:18,230 - Changing monitoring state from "Offline" to "Detecting serial connection"
2023-10-21 18:28:18,241 - Performing autodetection with 7 port/baudrate candidates: /dev/ttyACM0@115200, /dev/ttyACM0@250000, /dev/ttyACM0@230400, /dev/ttyACM0@57600, /dev/ttyACM0@38400, /dev/ttyACM0@19200, /dev/ttyACM0@9600
2023-10-21 18:28:18,251 - Trying port /dev/ttyACM0, baudrate 115200
2023-10-21 18:28:18,255 - Connecting to port /dev/ttyACM0, baudrate 115200
2023-10-21 18:28:18,279 - Handshake attempt #1 with timeout 2.0s
2023-10-21 18:28:18,283 - Connected to: Serial<id=0x684e0118, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2023-10-21 18:28:18,287 - Send: N0 M110 N0125
2023-10-21 18:28:20,297 - Handshake attempt #2 with timeout 2.0s
2023-10-21 18:28:20,305 - Send: N0 M110 N0
125
2023-10-21 18:28:22,307 - Handshake attempt #3 with timeout 2.0s
2023-10-21 18:28:22,322 - Send: N0 M110 N0125
2023-10-21 18:28:24,318 - Trying port /dev/ttyACM0, baudrate 250000
2023-10-21 18:28:24,321 - Handshake attempt #1 with timeout 2.0s
2023-10-21 18:28:24,335 - Send: N0 M110 N0
125
2023-10-21 18:28:26,337 - Handshake attempt #2 with timeout 2.0s
2023-10-21 18:28:26,349 - Send: N0 M110 N0125
2023-10-21 18:28:28,348 - Handshake attempt #3 with timeout 2.0s
2023-10-21 18:28:28,363 - Send: N0 M110 N0
125
2023-10-21 18:28:30,360 - Trying port /dev/ttyACM0, baudrate 230400
2023-10-21 18:28:30,363 - Handshake attempt #1 with timeout 2.0s
2023-10-21 18:28:30,380 - Send: N0 M110 N0125
2023-10-21 18:28:32,376 - Handshake attempt #2 with timeout 2.0s
2023-10-21 18:28:32,389 - Send: N0 M110 N0
125
2023-10-21 18:28:34,392 - Handshake attempt #3 with timeout 2.0s
2023-10-21 18:28:34,406 - Send: N0 M110 N0125
2023-10-21 18:28:36,407 - Trying port /dev/ttyACM0, baudrate 57600
2023-10-21 18:28:36,410 - Handshake attempt #1 with timeout 2.0s
2023-10-21 18:28:36,426 - Send: N0 M110 N0
125
2023-10-21 18:28:38,427 - Handshake attempt #2 with timeout 2.0s
2023-10-21 18:28:38,443 - Send: N0 M110 N0125
2023-10-21 18:28:40,439 - Handshake attempt #3 with timeout 2.0s
2023-10-21 18:28:40,455 - Send: N0 M110 N0
125
2023-10-21 18:28:42,463 - Trying port /dev/ttyACM0, baudrate 38400
2023-10-21 18:28:42,466 - Handshake attempt #1 with timeout 2.0s
2023-10-21 18:28:42,560 - Send: N0 M110 N0125
2023-10-21 18:28:44,483 - Handshake attempt #2 with timeout 2.0s
2023-10-21 18:28:44,496 - Send: N0 M110 N0
125
2023-10-21 18:28:46,500 - Handshake attempt #3 with timeout 2.0s
2023-10-21 18:28:46,513 - Send: N0 M110 N0125
2023-10-21 18:28:48,516 - Trying port /dev/ttyACM0, baudrate 19200
2023-10-21 18:28:48,518 - Handshake attempt #1 with timeout 2.0s
2023-10-21 18:28:48,538 - Send: N0 M110 N0
125
2023-10-21 18:28:50,542 - Handshake attempt #2 with timeout 2.0s
2023-10-21 18:28:50,555 - Send: N0 M110 N0125
2023-10-21 18:28:52,559 - Handshake attempt #3 with timeout 2.0s
2023-10-21 18:28:52,575 - Send: N0 M110 N0
125
2023-10-21 18:28:54,573 - Trying port /dev/ttyACM0, baudrate 9600
2023-10-21 18:28:54,575 - Handshake attempt #1 with timeout 2.0s
2023-10-21 18:28:54,592 - Send: N0 M110 N0125
2023-10-21 18:28:56,592 - Handshake attempt #2 with timeout 2.0s
2023-10-21 18:28:56,606 - Send: N0 M110 N0
125
2023-10-21 18:28:58,606 - Handshake attempt #3 with timeout 2.0s
2023-10-21 18:28:58,618 - Send: N0 M110 N0*125
2023-10-21 18:29:00,617 - Changing monitoring state from "Detecting serial connection" to "Error"
2023-10-21 18:29:00,656 - Changing monitoring state from "Error" to "Offline after error"
2023-10-21 18:29:00,667 - Connection closed, closing down monitor
Yes
octoprint-systeminfo-20231021185149.zip (22.4 KB)
See systeminfo.txt
Thanks.
Tom
Found the solution. Had to force the baud rate to 115200.
