This is a copy of a post on PrintTimeGenius repo. Everything need for posting here is included.
EDIT2: This is also happening with PrintTimeGenius disabled. Any idea what could cause this? I'll post this on Octoprint.
OctoPrint Version: Version 1.3.9
PrintTimeGenius Version (if you know): Latest
What did you try: Normal print
What happenned: 20 min print estimated as 3 hours
I've enclosed the gcode file (as .txt). lens test.txt
It happens with or without PrintTimeGenius which is weird. Also, I have seen it with two different files. I don't know if the problem happened before last release.
I think the problem is only happening with PrintTimeGenius. A new test looked good. I'll go back and test with PTG enable. I hope I'm not wasting everyone's time.
Although technically accurate this week, your post will be lying in a month from now. It's best if you visit the Plugin Manager and put the version you're using of the plugin in question.
When new people visit this post a few months from now they'll get the wrong impression that there's still a problem since the term "Latest" is fairly subjective over time.
