I'm new to 3D printing and got a printer 2nd hand from a friend that set it up with a Pi Zero 2 W, USB hat and Octoprint. We did a fresh image and install of octopi recently.
Small things print fine, usually less than 5 hours or so. But when printing larger prints I come back to the print head stopped mid print, not clogged or obstructed, just stopped mid layer. When I look at Octoprint it tells me: "SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)"
I've tried changing cables, both from the pi to the printer (Ender 3 v2) and power to the pi. I've changed power supplies for the pi from a 1a to a full 3a adapter. I've cleaned and leveled the print, changed filaments and tried to eliminate variables. I have disabled the pi camera and the USB webcam I was trying. It happens with and without cameras. It happens when the pi is inside and outside the enclosure.
EDIT: I tried running in safe mode, sending a print that was supposed to be 14ish hours. In safe mode the print failed to start. The bed heated up, and when I checked about 20 min later to see if it had started I had the same serial exception error in Ocotprint that I had before, but the print failed to start. I have uploaded the new sysinfo bundle below.
octoprint-systeminfo-20230122174830.zip (303.8 KB)
No, it failed to start printing.
logs.zip (134.3 KB)
I'm hoping that's done correctly. The log was something like 60mb so I deleted and commented where I removed what I believe was just gcode.
It's an Ender 3 v2. Octopi running on a pi Zero 2 W connected over wifi. The pi has a Zero4U USB hat that I've taken apart and making sure it has a good connection on the pins. I haven't done much with it other than try connecting a pi camera and a no name usb webcam (logitec clone) that didn't work so I put the config back to normal to mess with later.
I'm new to 3d printing, so any help is appreciated!
