Unable to configure my touch screen. Would appreciate help
Looked at websites which involve Raspbian/Jessie OS install for example Jessie Install but was unable to use mkdir I only installed OctoPi on my SD card.
Additional information about your setup (OctoPrint 1.5.1, OctoPi 0.17.0, printer, firmware, what kind of hardware precisely, ...)
octopi 0.17.0 is based on buster so it's possible this guides are outdated.
what happened when you tried to mkdir
I guess one thing you need is the desktop environment.
You can install it with
sudo /home/pi/scripts/install-desktop
I have done that but still didn't work. When I typed mkdir, it showed me unable to create directory
Did you use it with the folder name like mkdir test
or just mkdir
Depending where you want to create the folder you have to use sudo as in sudo mkdir test
I can't really help you with the display though.
mkdir test
or justmkdir
of course I would not just use 'mkdir'. But the mkdir is not really a concern at the moment but rather how to get the display working. Have attempted https://github.com/CytronTechnologies/xpt2046-LCD-Driver-for-Raspberry-Pi & https://www.elecrow.com/wiki/index.php?title=3.5_Inch_480x320_TFT_Display_with_Touch_Screen_for_Raspberry_Pi but does not seem to work. Since the LCD display I have is brandless I'm not sure which driver is compatible
This post might help you
