Direct connection works when all 6 pins are used to connect the pi to the einsy. However, i wanted to retain use of the external power supply for the pi so it was not dependent on the printer being ON to function. When removing the 5v and GRND pins for the equation, Octoprint will not connect to the printer.
Nothing. It works with all 6 pins, it does not work with only 4 pins. I dont know what else to try.
ocotopi 0.15.1, ocotoprint 1.3.8 on rpi 3b+
The reason i wanted to have the power seperate from the printer is because i wanted to be able to use the PSU control plugin to remote shutdown the printer. But from a clean cable management standpoint, having a direct connection inside the case (custom pi + einsy case from thingiverse) is much neater, and more attractive than running a USB cable from the bottom of the case to the top of the case, just to make the USB connection. Since it only seems to want to connect when using all 6 of the direct connection pins, that would probably lead to a corrupt SD card when cutting the power to the printer, without a proper pi shutdown.
So, basically, why are all 6 pins required for Octoprint to communicate with the printer? I can skip the 5V and GRND and give it power over its normal power supply. In my mind, it should still have everything it needs to be powered AND talk to the printer directly.
