3D printer control fullscreen mode
Very old MS Camera
I have 2 x printers running Octoprint on RPI4Bs. On one printer, when I hover the mouse pointer over the video window in the "Control" tab, the mouse cursor changes to a magnifying glass and if I double click, I can view the live video feed in full screen. On the other printer, with the same RPI, The mouse cursor remains as a pointer and I can't enter full screen video mode. Is there a setting that I can change to enable full screen video on the recalcitrant printer? Thanks for your help. Dave
Had a look in OP settings
no
octoprint-systeminfo-20240401141206.zip (6.7 KB)
See above
Latest Octopi image from RPI imager, RPI 4B Printer is a Prusa MK4
OctoPrint, out of the box, does not have an option for full screen webcam. This is most likely provided by a plugin you have on one instance of OctoPrint but not the other.
Thanks Charlie, I'll look and see which different plugins are installed on the one that works.
I found the problem - I had a plugin installed called fullscreen plugin on the instance of OP that was exhibiting the behavior that I wanted. I have now installed it on the other instance - problem solved. Thanks.
