I'm getting 2 different error messages flashing up on the TFT.
The first one is when i switch on the printer, and then the Pi powers up (I have a 5V supply from the printers PSU)
The error message says M21 Unknown command ... i see that M21 relates to the SD card (which the printer has, but from what i understand it is attached to the TFT)
So is there either a way to stop the M21 command being sent, or something i can tweak in the firmware ?
The second error message(s) comes up once the print starts .. Line number is not last line number+1, Line: xxx
This message pops up and if i clear it, another one pops up with an incremented number.
I left it alone and the print finished, but would like to understand what it is and how to fix it.
Researched as best i can.
Yes
Complete Logs
octoprint.log (166.6 KB) serial.log (3.0 MB)
