- Raspicam V2 on the Pi3B+
- Ethernet Vivotek IP8161 on internal LAN IP
I want to have acces to my octoprint from the outside. I need to control the printer state while printing thru webcams.
Redirecting the Raspi port to access it from outside works.
Redirecting the internal IP cam to internet work. But this in fact is a major security concern !
So, when I'm redirecting the only raspi port over the internet I can have access to the raspicam connected to the pi. Now on, I cannot have access to the internal IP8161 cam, (I'm using the multicam plugin)
tried several redirection configuration in order to make the octoprint see the internal web and relaying it thru it's IP
I don't think log are needed here.
1.5.3 Octoprint under 0.17 octopi on a Raspi3B+ Ethernet connected.
Raspicam V2 onboard
Vivotek IP8161 on conventional range IP
Multicam pug-in
Everything works fine on LAN.
So, trying several configuration and tinkering the internets I haven't found what I'm looking for.
My help need concern to have access to the second webcam (that is ethernet only) only by the octoprint environment, assuming it's the only that have a "user/login" connection that set a good (even if low) access security.
Clues ?
