While in the browser with Octoprint running on Windows 10, need to transfer local files(gcode) to the SD on the printer.
Moving manually onto SD card then printer
Octoprint 1.4.2 running on 32 bit Windows 10 on Dell Dimension 4700
You do not need to remove the SD card from the printer.
When you drag the files from File Manager to the Octopi window in the browser, I.E. Chrome, or Firefox, you should drag them to the Right side to load them to the SD card in the printer. This is not the best method since Octoprint only displays 8 characters of the filename.
You should drag the file to the Left side of the browser window, the file will go to the Octopi memory and you can print it from there and see the whole filename.
Whether upload to SD via the described drag-n-drop behaviour in OctoPrint works has nothing to do with 8 vs 32bit though, it depends on whether the firmware indicates support for the sd card protocol parts or not. In any case it will be bog slow.
Sry - @Salty-Doug and @foosel are completely right.
For some reason the sd support didn't work for me a few months ago when I switched to 32 bit and I thought that's how 32 bit boards behave and didn't test it again ever since.
