Accessing Octoprint using Tailscale results in warning that internet access is detected
I do not have a direct network connection to the RaspberryPi that's running octoprint.
As I am using Tailscale for all my home server needs and avoid direct access from the internet to any of my containers or machines, I installed Tailscale on the octoprint server as well.
This works well, I can ssh into the machine and also access the web interface.
(As I'm using a Let's encrypt wildcard certificate for my domain, I placed that on the Raspberry as well and have haproxy as the https terminator.)
The problem is that I get the warning about accessing octoprint over the internet, which I assume that I'm not.
I read the articles about safe remote access.
I configured the accessControl as follows:
accessControl:
  addRemoteUsers: false
  autologinAs: octo
  autologinHeadsupAcknowledged: true
  autologinLocal: true
  checkBasicAuthenticationPassword: true
  defaultReauthenticationTimeout: 5
  localNetworks:
  - 127.0.0.0/8
  - 100.64.0.0/10
  remoteUserHeader: REMOTE_USER
  trustBasicAuthentication: false
  trustRemoteUser: false
  userManager: octoprint.access.users.FilebasedUserManager
The cidr notation 100.64.0.0/10 is the shared ip address as of RFC 6598, Tailscale hands out IP-adresses in this range (as far as I can see).
The reverse proxy test has the following first lines:
Variable Source Client Server
Client IP X-Forwarded-For - 100.120.60.71
The client IP address is as expected - it is the IP-address that Tailscale assigned to the client that I am using. So from my point of view, octoprint should see this client as part of a local network and should do autologin (according to the accessControl config) and not warn about accessing it from the internet.
(I have to admit that I not all that sure about the autologin - and that is only a first-world-problem. I'm more worried about the warning, that I am accessing octoprint through the internet, which is hopefully a false positive...)
Does not seem to be applicable to me.
octoprint-systeminfo-20251207113551.zip (115.7 KB)
I assume, that I have given the relevant infos. Please tell me, if you need other info.
So I assume this is covering all of tailscale's possible networks, which translates to 100.64.0.1 - 100.127.255.254.
This IP is in that range. Are you accessing OctoPrint using the public name you have registered for your wildcard? Does it do the same if you access by ip address alone?
I just tested with my instance and using tailscale IP to access and autologin works as expected.
@jneilliii - Thank you for your feedback.
Regarding auto-login I must have made a mistake - it's currently working, regardless of using the IP or the subdomain/domain-name.
My main concern - the warning about accessing octoprint from the internet persists - also in both cases and I would very much like to see, whether I made a mistake or whether this is a false positive. In the latter case I would like to get rid of it...
