Accessing the Pi environment
Loaded Python 3. Loaded firmware updater. Updater fails after configured. Says /usr/bin/avrdude does not exist. So I forgot how to access the pi (SSH??) what do I need? New computer, so any programs I used before for this are not loaded. This is a serious brainfart on my part.
Don't remember where to start.
NA
NA
First, most important question - what OS is your new computer.
The internet has a lot of guides of 'how to use SSH to access an RPi' you could use, and it's built into most OSes now, using ssh pi@ipAddress command.
windows 11
Hi.
I'm using https://mobaxterm.mobatek.net/
I assuming that You remember login and password.
Tom
Hi again,
I figured out that I can get into the raspberry environment with putty. I have logged in and have searched thru all the directories looking for the /usr/bin/avrdude path. I does not exist. This is on another Rip that I have. Its been working fine until I reimaged my Rip to have Python 3 on it. Again, I loaded the addon for the firmware updater, using the same parameters I used before and what is documented on the firmware information page. This second Rip has the same issue when configuring the FW addon. Any ideas?
Thanks in Advance!
You have to install avrdude, it doesn't come pre-installed.
