Achievements shows error:
There was an error with the template dialogs/about.jinja2 at line number 48: unsupported format character 'Z' (0x5a) at index 93
reload Octoprint, reboot Octoprint Pi
Yes
octoprint-systeminfo-20240518192753.zip (112.8 KB)
OctoPi
The ready-to-go Raspberry Pi image with OctoPrint
Version 0.17.0, running on Raspberry Pi 3 Model B Rev 1.2
Same error here, since update to 1.10.1
Same here, found this morning
How can this help to find a solution?
@pc-bastler provided a systeminfo bundle.
Do you think if I provide an additional one, the situation will be better? 2 person already provide a bundle, are you sure a third one will help more? If yes I've no problem with that. If not, my message was the hint that this isn't a problem of only two persons. That was my intention with the message.
I only count one.
Just to say
Hottabych:
Same here
Does not help at all.
It's only meant to build up pressure on the devs.
More than one systeminfo bundle is certainly useful, as it allows us to spot patterns or common characteristics of your OctoPrint install, to work out why the issue is occuring. Just adding "me too" doesn't do this.
Well, no problem, here you are.
octoprint-systeminfo-20240519002703.zip (119,2 KB)
No problem at all, a fresh one - some minutes ago.
octoprint-systeminfo-20240520095848.zip (125,7 KB)
@Charlie_Powell @foosel could this be something related to a json timestamp, which typically includes a "Z" value at the end for timezone offset?
foosel
May 22, 2024, 7:52pm
11
Known issue, fix ready for 1.10.2:
opened 09:06AM - 21 May 24 UTC
bug
done
### The problem
When I open the achievements plugin, I get this error:
`Ther⦠e was an error with the template dialogs/about.jinja2 at line number 48: unsupported format character 'Z' (0x5a) at index 93`
This appears since I updated to 1.10.1 - in 1.10.0 it was possible to open the achievements page as normal.
### Did the issue persist even in safe mode?
Yes, it did persist
### If you could not test in safe mode, please state why ("currently printing" is NOT an excuse!)
_No response_
### Version of OctoPrint
OctoPrint 1.10.1
### Operating system running OctoPrint
OctoPi* 1.0.0cam (build 2023.10.09.154319)
### Printer model & used firmware incl. version
Prusa MK3S+ MMU3 version 3.13.2
### Browser and version of browser, operating system running browser
Brave 1.65.132 on macOS Monterey 12.7.4
### Checklist of files to include below
- [X] Systeminfo Bundle (always include!)
- [X] Contents of the JavaScript browser console (always include in cases of issues with the user interface)
- [X] Screenshots and/or videos showing the problem (always include in case of issues with the user interface)
- [ ] GCODE file with which to reproduce (always include in case of issues with GCODE analysis or printing behaviour)
### Additional information & file uploads
[octoprint-systeminfo-20240521110043.zip](https://github.com/OctoPrint/OctoPrint/files/15387395/octoprint-systeminfo-20240521110043.zip)
<img width="2549" alt="Screenshot 21 05 2024 um 11 03 35 AM" src="https://github.com/OctoPrint/OctoPrint/assets/1634208/bae565dc-bf49-484f-842f-6bd04352ca1c">
Until then, switch to English (User Settings or Settings > Appearance, or ?l10n=en on the URL), this only affects the German translation.
system
Closed
August 20, 2024, 7:52pm
12
