Camera model : Random Action Camera
What is the problem? : I''m able to use it sometimes, it works perfectly, but when I try to start it again, I choose PC mode that it's what works and it shows fine for a second, and then disconnects.
What did you already try to solve it? : I changed parameters in octopi config text, removed -f fps, used -y to try again, and changed the default camera to auto to camera usb. I also tried with more USB cables.
Logs (/var/log/webcamd.log, syslog, dmesg, ...)
