Add buttons to send comands to pi
i want to add a button
tried plugins
no
no
i have tried the usb relay plugin i cant get it to work so i am looking for a way of adding a button to the top bar etc to send comands to the pi ie-
to open relay
echo -e '\xA0\x01\x01\xA2' > /dev/ttyUSB0
and to close it
echo -e '\xA0\x01\x00\xA1' > /dev/ttyUSB0
any help would be much apreciated
thanks
martin
i did try adding this to the config yaml with no luck
system:
actions:
  • action: relayonoff
    command: echo -e '\xA0\x01\x01\xA2' > /dev/ttyUSB0
    confirm: false
    name: turn relay on
  • action: relayoff
    command: echo -e '\xA0\x01\x00\xA1' > /dev/ttyUSB0
    confirm: false
    name: turn relay off
sorted it
just added
    command: sudo echo -e '\xA0\x01\x01\xA2' > /dev/ttyUSB0
    confirm: false
    name: turn relay on
    • action: relayoff
      command: sudo echo -e '\xA0\x01\x00\xA1' > /dev/ttyUSB0
      confirm: false
to the config yaml.
hope it helps someone else
martin
