Hello:) If information is needed, please ask.
I would like to add a printer profile. However, this is not possible. When saving I get the error
"Could not add profile
There was unexpected error while saving the printer profile, please consult the logs."
The error also occurs in safe mode.
What data i tried to add. Everything is default except printer size 300x300x400 and Name "Sidewinder" and Model "X1"
Save mode started. logs checked. raspberry restarted.
yes. information above
yes i tried safe mode and no, it not solved my problem
OctoPrint: 1.6.1
File Check Plugin: 2021.2.23
Firmware Check Plugin: 2021.8.11
Pi Support Plugin: 2021.8.2
Raspberry Pi 4
Octoprint.log
This is the part after i tried to save the new profile. the log was generated in safe mode
2021-08-25 10:47:36,992 - octoprint.access.users - INFO - Logged in user: MrDark7199
2021-08-25 10:47:40,461 - octoprint.server.util.flask - INFO - Passively logging in user MrDark7199 from ::ffff:192.168.178.59
2021-08-25 10:47:40,462 - octoprint.access.users - INFO - Logged in user: MrDark7199
2021-08-25 10:47:45,754 - octoprint - ERROR - Exception on /api/printerprofiles [GET]
File "/home/pi/oprint/lib/python3.7/site-packages/flask/app.py", line 2447, in wsgi_app
response = self.full_dispatch_request()
File "/home/pi/oprint/lib/python3.7/site-packages/flask/app.py", line 1952, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/home/pi/oprint/lib/python3.7/site-packages/flask/app.py", line 1821, in handle_user_exception
reraise(exc_type, exc_value, tb)
File "/home/pi/oprint/lib/python3.7/site-packages/flask/_compat.py", line 39, in reraise
raise value
File "/home/pi/oprint/lib/python3.7/site-packages/flask/app.py", line 1950, in full_dispatch_request
rv = self.dispatch_request()
File "/home/pi/oprint/lib/python3.7/site-packages/flask/app.py", line 1936, in dispatch_request
return self.view_functions[rule.endpoint](**req.view_args)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/server/util/flask.py", line 1317, in decorated_function
response = f(*args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/server/util/flask.py", line 1550, in decorated_view
return func(*args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/vendor/flask_principal.py", line 199, in _decorated
rv = f(*args, **kw)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/server/api/printer_profiles.py", line 53, in printerProfilesList
all_profiles = printerProfileManager.get_all()
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/printer/profile.py", line 353, in get_all
return self._load_all()
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/printer/profile.py", line 483, in _load_all
profile = self._load_from_path(path)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/printer/profile.py", line 514, in _load_from_path
profile = yaml.safe_load(f)
File "/home/pi/oprint/lib/python3.7/site-packages/yaml/__init__.py", line 162, in safe_load
return load(stream, SafeLoader)
File "/home/pi/oprint/lib/python3.7/site-packages/yaml/__init__.py", line 112, in load
loader = Loader(stream)
File "/home/pi/oprint/lib/python3.7/site-packages/yaml/loader.py", line 34, in __init__
Reader.__init__(self, stream)
File "/home/pi/oprint/lib/python3.7/site-packages/yaml/reader.py", line 85, in __init__
self.determine_encoding()
File "/home/pi/oprint/lib/python3.7/site-packages/yaml/reader.py", line 124, in determine_encoding
self.update_raw()
File "/home/pi/oprint/lib/python3.7/site-packages/yaml/reader.py", line 178, in update_raw
data = self.stream.read(size)
File "/home/pi/oprint/lib/python3.7/codecs.py", line 322, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xb0 in position 0: invalid start byte
2021-08-25 10:47:49,064 - octoprint.plugins.camerasettings - INFO - Excluding camera bcm2835-isp-capture0 based on ^bcm2835-isp-\w+$
2021-08-25 10:47:49,065 - octoprint.plugins.camerasettings - INFO - Excluding camera bcm2835-codec-isp based on ^bcm2835-codec-\w+$
2021-08-25 10:47:52,477 - octoprint.plugins.camerasettings - INFO - Excluding camera bcm2835-codec-decode based on ^bcm2835-codec-\w+$
2021-08-25 10:47:52,480 - octoprint.plugins.camerasettings - INFO - Excluding camera bcm2835-isp-capture1 based on ^bcm2835-isp-\w+$
2021-08-25 10:47:52,483 - octoprint.plugins.camerasettings - INFO - Excluding camera bcm2835-isp-output0 based on ^bcm2835-isp-\w+$
2021-08-25 10:47:52,487 - octoprint.plugins.camerasettings - INFO - Excluding camera bcm2835-codec-encode based on ^bcm2835-codec-\w+$
2021-08-25 10:47:52,490 - octoprint.plugins.camerasettings - INFO - Excluding camera bcm2835-isp-stats2 based on ^bcm2835-isp-\w+$
2021-08-25 10:48:10,099 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.178.59
2021-08-25 10:48:10,282 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.178.59
2021-08-25 10:48:10,464 - octoprint.server.util.flask - INFO - Passively logging in user MrDark7199 from ::ffff:192.168.178.59
2021-08-25 10:48:10,464 - octoprint.access.users - INFO - Logged in user: MrDark7199
2021-08-25 10:48:10,491 - octoprint.server.util.sockjs - INFO - User MrDark7199 logged in on the socket from client ::ffff:192.168.178.59
2021-08-25 10:48:12,345 - octoprint.plugins.PrintJobHistory - ERROR - Filamentracking is disabled, but some plugins are installed!
2021-08-25 10:49:04,768 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.178.59
