I would like to add some custom icons to Octoprint. I'm not sure if the system and plugins share the same set of icons but in certain plug-ins (like "UI Customizer") they allow me to choose an icon for something like a control button. I want to add an icons that looks like an enclosure+thermometer, enclosure+fan, etc.
Is there a folder that I can drop new icons in? If so can I access it through Octoprint?
I can't see anything special when I take the octoprint SD card out and pop it into my computer.
It's not images, it's a font (remember Wingdings on old PCs? This font that displays all sorts of icons and numbers when you change a normal text to it in MS Word?):
Thanks. I have been kinda busy with a bit private projects the last couple of days. Will update my plugin, and couple of other things and then look into the bugs. The icon picker needs a bit more generic handling.
