Since I moved the printer from one location to another in the same room and trying to update, my ender 3 pro does not print with octoprint. if I try to preheat the printer it does not heat up and gives me the following error message "E1 printer halted during heating please reset ". Same thing if I try to move on any axis, but I get this message "Homing failed printer halted please reset".
What is even weirder is that I can launch any print in safe mode, but it won't print because nothing will heat up and a some point minutes later It will also stop and say "bed heating failed printer halted please reset". And in addition I had a lightning logo next to the on off button wich has disappeared.
I checked all the wiring and elements of the printer, replaced the data of the sd card of my raspberry 3 with a precedent version
YES
NO
terminal information :
Serial port list: ['/dev/ttyUSB0']
Connecting to: /dev/ttyUSB0
Connected to: Serial<id=0x6b07dd70, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
Send: N0 M110 N0*125
Recv: start
Recv: echo:Marlin TH3D U1.R2.12
Recv:
Recv: echo: Last Updated: | Author: (TH3D)
Recv: echo:Compiled: Jul 27 2019
Recv: echo: Free Memory: 11373 PlannerBufferBytes: 1488
Recv: echo:V55 stored settings retrieved (655 bytes; crc 51363)
Recv: echo: G21 ; (mm)
Recv: echo: M149 C ; Units in Celsius
Recv:
Recv: echo:Steps per unit:
Recv: echo: M92 X80.00 Y80.00 Z400.00 E95.00
Recv: echo:Maximum feedrates (units/s):
Recv: echo: M203 X200.00 Y200.00 Z15.00 E50.00
Recv: echo:Maximum Acceleration (units/s2):
Recv: echo: M201 X500 Y800 Z500 E5000
Recv: echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
Recv: echo: M204 P500.00 R500.00 T500.00
Recv: echo:Advanced: Q<min_segment_time_us> S<min_feedrate> T<min_travel_feedrate> J<junc_dev>
Recv: echo: M205 Q20000 S0.00 T0.00 J0.02
Recv: echo:Auto Bed Leveling:
Recv: echo: M420 S0
Recv: echo: G29 W I0 J0 Z-0.19700
Recv: echo: G29 W I1 J0 Z0.01250
Recv: echo: G29 W I2 J0 Z0.31800
Recv: echo: G29 W I0 J1 Z-0.21650
Recv: echo: G29 W I1 J1 Z-0.07250
Recv: echo: G29 W I2 J1 Z0.25600
Recv: echo: G29 W I0 J2 Z-0.14600
Recv: echo: G29 W I1 J2 Z0.01850
Recv: echo: G29 W I2 J2 Z0.55800
Recv: echo:PID settings:
Recv: echo: M301 P27.15 I2.53 D72.84
Recv: echo:Z-Probe Offset (mm):
Recv: echo: M851 Z-1.70
Recv: echo:SD init fail
Recv: ok
Changing monitoring state from "Connecting" to "Operational"
Recv: ok
Send: N1 M115*39
Recv: FIRMWARE_NAME:Marlin TH3D U1.R2.12 SOURCE_CODE_URL: PROTOCOL_VERSION:1.0 MACHINE_TYPE:Ender 3 EXTRUDER_COUNT:1 UUID:
Recv: ok
Send: M21
Changing monitoring state from "Operational" to "Starting"
Recv: ok
Recv: ok
Changing monitoring state from "Starting" to "Printing"
Send: N1 G90*17
Recv: ok
Send: N2 M83*26
Recv: ok
Send: N3 M106 S0*100
Recv: ok
Send: N4 M140 S70*86
Recv: ok
Send: N5 M190 S70*90
Recv: T:27.30 /0.00 B:27.06 /70.00 @:0 B@:0 W:?
Recv: T:28.10 /0.00 B:27.22 /70.00 @:0 B@:127 W:?
Recv: T:28.61 /0.00 B:27.25 /70.00 @:0 B@:127 W:?
Recv: T:27.93 /0.00 B:27.09 /70.00 @:0 B@:127 W:?
Recv: T:27.98 /0.00 B:27.66 /70.00 @:0 B@:127 W:?
Recv: T:28.04 /0.00 B:27.31 /70.00 @:0 B@:127 W:?
Recv: T:27.84 /0.00 B:26.56 /70.00 @:0 B@:127 W:?
Recv: T:28.49 /0.00 B:27.56 /70.00 @:0 B@:127 W:?
Recv: T:27.87 /0.00 B:26.91 /70.00 @:0 B@:127 W:?
Recv: T:27.44 /0.00 B:27.78 /70.00 @:0 B@:127 W:?
Recv: T:28.55 /0.00 B:27.22 /70.00 @:0 B@:127 W:?
Recv: T:27.98 /0.00 B:26.91 /70.00 @:0 B@:127 W:?
Recv: T:27.95 /0.00 B:27.41 /70.00 @:0 B@:127 W:?
Recv: T:28.52 /0.00 B:27.16 /70.00 @:0 B@:127 W:?
Recv: T:28.38 /0.00 B:26.94 /70.00 @:0 B@:127 W:?
Recv: T:27.87 /0.00 B:26.94 /70.00 @:0 B@:127 W:?
Recv: T:28.32 /0.00 B:27.62 /70.00 @:0 B@:127 W:?
Recv: T:28.10 /0.00 B:26.97 /70.00 @:0 B@:127 W:?
Recv: T:28.38 /0.00 B:27.56 /70.00 @:0 B@:127 W:?
Recv: T:28.18 /0.00 B:27.44 /70.00 @:0 B@:127 W:?
Recv: T:27.84 /0.00 B:26.87 /70.00 @:0 B@:127 W:?
Recv: T:28.18 /0.00 B:27.53 /70.00 @:0 B@:127 W:?
Recv: T:28.49 /0.00 B:27.28 /70.00 @:0 B@:127 W:?
Recv: T:28.12 /0.00 B:27.22 /70.00 @:0 B@:127 W:?
Recv: T:27.76 /0.00 B:27.28 /70.00 @:0 B@:127 W:?
Recv: T:28.24 /0.00 B:27.25 /70.00 @:0 B@:127 W:?
Recv: T:27.95 /0.00 B:27.75 /70.00 @:0 B@:127 W:?
Recv: T:28.32 /0.00 B:27.59 /70.00 @:0 B@:127 W:?
Recv: T:28.21 /0.00 B:26.87 /70.00 @:0 B@:127 W:?
Recv: T:27.59 /0.00 B:26.94 /70.00 @:0 B@:127 W:?
Recv: T:28.12 /0.00 B:27.53 /70.00 @:0 B@:127 W:?
Recv: T:28.32 /0.00 B:26.97 /70.00 @:0 B@:127 W:?
Recv: T:27.98 /0.00 B:27.28 /70.00 @:0 B@:127 W:?
Recv: T:28.01 /0.00 B:27.50 /70.00 @:0 B@:127 W:?
Recv: T:28.38 /0.00 B:27.37 /70.00 @:0 B@:127 W:?
Recv: T:27.93 /0.00 B:26.94 /70.00 @:0 B@:127 W:?
Recv: T:28.38 /0.00 B:27.50 /70.00 @:0 B@:127 W:?
Recv: T:28.04 /0.00 B:26.94 /70.00 @:0 B@:127 W:?
Recv: T:27.64 /0.00 B:27.50 /70.00 @:0 B@:127 W:?
Recv: T:28.47 /0.00 B:27.28 /70.00 @:0 B@:127 W:?
Recv: T:28.07 /0.00 B:26.91 /70.00 @:0 B@:127 W:?
Recv: T:28.24 /0.00 B:27.59 /70.00 @:0 B@:127 W:?
Recv: T:28.30 /0.00 B:27.28 /70.00 @:0 B@:127 W:?
Recv: T:27.70 /0.00 B:27.09 /70.00 @:0 B@:127 W:?
Recv: T:28.32 /0.00 B:27.34 /70.00 @:0 B@:127 W:?
Recv: T:27.93 /0.00 B:27.28 /70.00 @:0 B@:127 W:?
Recv: T:28.10 /0.00 B:27.69 /70.00 @:0 B@:127 W:?
Recv: T:28.30 /0.00 B:27.25 /70.00 @:0 B@:127 W:?
Recv: T:27.98 /0.00 B:27.62 /70.00 @:0 B@:127 W:?
Recv: T:28.27 /0.00 B:27.56 /70.00 @:0 B@:127 W:?
Recv: T:27.84 /0.00 B:27.53 /70.00 @:0 B@:127 W:?
Recv: T:28.30 /0.00 B:27.69 /70.00 @:0 B@:127 W:?
Recv: T:28.04 /0.00 B:27.78 /70.00 @:0 B@:127 W:?
Recv: T:28.32 /0.00 B:27.75 /70.00 @:0 B@:127 W:?
Recv: T:28.10 /0.00 B:27.09 /70.00 @:0 B@:127 W:?
Recv: T:27.47 /0.00 B:27.37 /70.00 @:0 B@:127 W:?
Recv: T:28.12 /0.00 B:27.50 /70.00 @:0 B@:127 W:?
Recv: T:28.12 /0.00 B:27.59 /70.00 @:0 B@:127 W:?
Recv: T:28.01 /0.00 B:27.59 /70.00 @:0 B@:127 W:?
Recv: T:28.35 /0.00 B:27.37 /70.00 @:0 B@:127 W:?
Recv: T:28.12 /0.00 B:27.72 /70.00 @:0 B@:127 W:?
Recv: T:28.44 /0.00 B:27.69 /70.00 @:0 B@:127 W:?
Recv: T:28.01 /0.00 B:27.12 /70.00 @:0 B@:127 W:?
Recv: T:27.95 /0.00 B:27.66 /70.00 @:0 B@:127 W:?
Recv: T:28.24 /0.00 B:27.47 /70.00 @:0 B@:127 W:?
Recv: T:28.07 /0.00 B:27.62 /70.00 @:0 B@:127 W:?
Recv: T:28.41 /0.00 B:27.87 /70.00 @:0 B@:127 W:?
Recv: T:28.32 /0.00 B:27.50 /70.00 @:0 B@:127 W:?
Recv: T:27.67 /0.00 B:27.16 /70.00 @:0 B@:127 W:?
Recv: T:28.49 /0.00 B:27.47 /70.00 @:0 B@:127 W:?
Recv: T:28.30 /0.00 B:27.84 /70.00 @:0 B@:127 W:?
Recv: T:28.47 /0.00 B:27.25 /70.00 @:0 B@:127 W:?
Recv: T:27.90 /0.00 B:27.25 /70.00 @:0 B@:127 W:?
Recv: T:28.47 /0.00 B:27.69 /70.00 @:0 B@:127 W:?
Recv: T:28.38 /0.00 B:27.72 /70.00 @:0 B@:127 W:?
Recv: T:28.44 /0.00 B:27.34 /70.00 @:0 B@:127 W:?
Recv: T:28.07 /0.00 B:27.59 /70.00 @:0 B@:127 W:?
Recv: T:28.15 /0.00 B:27.22 /70.00 @:0 B@:127 W:?
Recv: T:28.38 /0.00 B:27.87 /70.00 @:0 B@:127 W:?
Recv: T:28.24 /0.00 B:27.28 /70.00 @:0 B@:127 W:?
Recv: T:27.90 /0.00 B:27.44 /70.00 @:0 B@:127 W:?
Recv: T:28.24 /0.00 B:27.75 /70.00 @:0 B@:127 W:?
Recv: T:28.47 /0.00 B:27.34 /70.00 @:0 B@:127 W:?
Recv: T:28.27 /0.00 B:27.69 /70.00 @:0 B@:127 W:?
Recv: T:28.27 /0.00 B:27.78 /70.00 @:0 B@:127 W:?
Recv: T:28.52 /0.00 B:27.56 /70.00 @:0 B@:127 W:?
Recv: T:28.15 /0.00 B:27.94 /70.00 @:0 B@:127 W:?
Recv: T:28.64 /0.00 B:27.62 /70.00 @:0 B@:127 W:?
Recv: T:28.04 /0.00 B:27.06 /70.00 @:0 B@:127 W:?
Recv: T:28.01 /0.00 B:27.78 /70.00 @:0 B@:127 W:?
Recv: T:28.38 /0.00 B:27.53 /70.00 @:0 B@:127 W:?
Recv: T:28.21 /0.00 B:27.25 /70.00 @:0 B@:127 W:?
Recv: T:28.18 /0.00 B:27.69 /70.00 @:0 B@:127 W:?
Recv: T:28.55 /0.00 B:27.91 /70.00 @:0 B@:127 W:?
Recv: T:28.47 /0.00 B:27.44 /70.00 @:0 B@:127 W:?
Recv: T:27.95 /0.00 B:27.47 /70.00 @:0 B@:127 W:?
Recv: T:28.15 /0.00 B:27.47 /70.00 @:0 B@:127 W:?
Recv: T:28.30 /0.00 B:27.91 /70.00 @:0 B@:127 W:?
Recv: T:28.44 /0.00 B:27.31 /70.00 @:0 B@:127 W:?
Recv: T:27.87 /0.00 B:27.34 /70.00 @:0 B@:127 W:?
Recv: T:28.21 /0.00 B:27.87 /70.00 @:0 B@:127 W:?
Recv: T:28.52 /0.00 B:27.81 /70.00 @:0 B@:127 W:?
Recv: T:28.41 /0.00 B:27.50 /70.00 @:0 B@:127 W:?
Recv: T:27.98 /0.00 B:27.75 /70.00 @:0 B@:127 W:?
Recv: T:28.15 /0.00 B:27.28 /70.00 @:0 B@:127 W:?
Recv: T:28.12 /0.00 B:28.00 /70.00 @:0 B@:127 W:?
Recv: T:28.49 /0.00 B:27.97 /70.00 @:0 B@:127 W:?
Recv: T:28.38 /0.00 B:27.31 /70.00 @:0 B@:127 W:?
Recv: T:27.95 /0.00 B:27.62 /70.00 @:0 B@:127 W:?
Recv: T:28.35 /0.00 B:27.84 /70.00 @:0 B@:127 W:?
Recv: T:28.55 /0.00 B:27.41 /70.00 @:0 B@:127 W:?
Recv: T:28.12 /0.00 B:27.75 /70.00 @:0 B@:127 W:?
Recv: T:28.55 /0.00 B:27.53 /70.00 @:0 B@:127 W:?
Recv: T:28.35 /0.00 B:27.97 /70.00 @:0 B@:127 W:?
Recv: T:28.58 /0.00 B:27.75 /70.00 @:0 B@:127 W:?
Recv: T:28.12 /0.00 B:27.06 /70.00 @:0 B@:127 W:?
Recv: T:28.01 /0.00 B:27.81 /70.00 @:0 B@:127 W:?
Recv: T:28.44 /0.00 B:27.66 /70.00 @:0 B@:127 W:?
Recv: T:28.21 /0.00 B:27.47 /70.00 @:0 B@:127 W:?
Recv: T:27.98 /0.00 B:27.84 /70.00 @:0 B@:127 W:?
Recv: T:28.44 /0.00 B:28.12 /70.00 @:0 B@:127 W:?
Recv: T:28.44 /0.00 B:27.44 /70.00 @:0 B@:127 W:?
Recv: T:28.49 /0.00 B:27.87 /70.00 @:0 B@:127 W:?
Recv: T:28.52 /0.00 B:27.44 /70.00 @:0 B@:127 W:?
Recv: T:28.30 /0.00 B:28.03 /70.00 @:0 B@:127 W:?
Recv: T:28.41 /0.00 B:27.44 /70.00 @:0 B@:127 W:?
Recv: T:27.76 /0.00 B:27.44 /70.00 @:0 B@:127 W:?
Recv: T:28.21 /0.00 B:27.94 /70.00 @:0 B@:127 W:?
Recv: T:28.49 /0.00 B:27.94 /70.00 @:0 B@:127 W:?
Recv: T:28.21 /0.00 B:27.59 /70.00 @:0 B@:127 W:?
Recv: T:27.95 /0.00 B:27.84 /70.00 @:0 B@:127 W:?
Recv: T:28.10 /0.00 B:27.44 /70.00 @:0 B@:127 W:?
Recv: T:28.35 /0.00 B:28.03 /70.00 @:0 B@:127 W:?
Recv: T:28.38 /0.00 B:28.00 /70.00 @:0 B@:127 W:?
Recv: T:28.32 /0.00 B:27.37 /70.00 @:0 B@:127 W:?
Recv: T:27.93 /0.00 B:27.81 /70.00 @:0 B@:127 W:?
Recv: T:28.44 /0.00 B:27.94 /70.00 @:0 B@:127 W:?
Recv: T:28.52 /0.00 B:27.59 /70.00 @:0 B@:127 W:?
Recv: T:28.18 /0.00 B:27.75 /70.00 @:0 B@:127 W:?
Recv: T:28.24 /0.00 B:28.06 /70.00 @:0 B@:127 W:?
Recv: T:27.84 /0.00 B:27.41 /70.00 @:0 B@:127 W:?
Recv: T:28.30 /0.00 B:27.94 /70.00 @:0 B@:127 W:?
Recv: T:28.64 /0.00 B:27.78 /70.00 @:0 B@:127 W:?
Recv: T:28.07 /0.00 B:27.44 /70.00 @:0 B@:127 W:?
Recv: T:28.07 /0.00 B:28.03 /70.00 @:0 B@:127 W:?
Recv: T:28.44 /0.00 B:27.75 /70.00 @:0 B@:127 W:?
Recv: T:28.07 /0.00 B:27.37 /70.00 @:0 B@:127 W:?
Recv: T:28.10 /0.00 B:28.00 /70.00 @:0 B@:127 W:?
Recv: T:28.35 /0.00 B:28.19 /70.00 @:0 B@:127 W:?
Recv: T:28.30 /0.00 B:27.56 /70.00 @:0 B@:127 W:?
Recv: T:28.41 /0.00 B:28.12 /70.00 @:0 B@:127 W:?
Recv: T:28.44 /0.00 B:27.50 /70.00 @:0 B@:127 W:?
Recv: T:27.78 /0.00 B:27.59 /70.00 @:0 B@:127 W:?
Recv: T:28.21 /0.00 B:27.97 /70.00 @:0 B@:127 W:?
Recv: T:28.61 /0.00 B:27.97 /70.00 @:0 B@:127 W:?
Recv: T:28.32 /0.00 B:27.47 /70.00 @:0 B@:127 W:?
Recv: T:28.15 /0.00 B:27.56 /70.00 @:0 B@:127 W:?
Recv: T:28.30 /0.00 B:28.19 /70.00 @:0 B@:127 W:?
Recv: T:28.58 /0.00 B:28.12 /70.00 @:0 B@:127 W:?
Recv: T:28.12 /0.00 B:27.34 /70.00 @:0 B@:127 W:?
Recv: T:27.90 /0.00 B:27.78 /70.00 @:0 B@:127 W:?
Recv: T:28.41 /0.00 B:27.97 /70.00 @:0 B@:127 W:?
Recv: T:28.49 /0.00 B:27.50 /70.00 @:0 B@:127 W:?
Recv: T:28.15 /0.00 B:28.09 /70.00 @:0 B@:127 W:?
Recv: T:28.27 /0.00 B:28.22 /70.00 @:0 B@:127 W:?
Recv: T:27.90 /0.00 B:27.53 /70.00 @:0 B@:127 W:?
Recv: Error:Heating failed, system stopped! Heater_ID: bed
Recv: Error:Printer halted. kill() called!
Changing monitoring state from "Printing" to "Error: Heating failed, system stopped! Heater_ID: bed - Printer halted. kill() called!"
Send: M112
Send: N6 M112*39
Send: N7 M104 T0 S0*38
Send: N8 M140 S0*109
Changing monitoring state from "Error: Heating failed, system stopped! Heater_ID: bed - Printer halted. kill() called!" to "Offline (Error: Heating failed, system stopped! Heater_ID: bed - Printer halted. kill() called!)"
Connected to: Serial<id=0x6a45cbb0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Recv: start
Recv:
Recv:
Recv: echo: M420 S0
Recv: ok
Recv: ok
Send: N1 M115*39
Recv: ok
Send: M21
Recv: ok
Send: G91
Recv: ok
Send: G28 X0 Y0
Recv: echo:busy: processing
Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
Changing monitoring state from "Operational" to "Error: Printer halted. kill() called!"
Send: M112
Send: N2 M112*35
Send: N3 M104 T0 S0*34
Send: N4 M140 S0*97
Changing monitoring state from "Error: Printer halted. kill() called!" to "Offline (Error: Printer halted. kill() called!)"
</small>
<small>
Connected to: Serial<id=0x6bf21f30, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Recv: start
Recv:
Recv:
Recv: echo: M420 S0
Recv: ok
Recv: ok
Send: N1 M115*39
Recv: ok
Send: M21
Recv: ok
Send: M104 S180
Recv: ok
Send: M105
Recv: ok T:28.30 /180.00 B:27.47 /0.00 @:127 B@:0
Send: M105
Recv: ok T:28.44 /180.00 B:28.00 /0.00 @:127 B@:0
Send: M105
Recv: ok T:28.58 /180.00 B:27.53 /0.00 @:127 B@:0
Send: M105
Recv: ok T:28.47 /180.00 B:27.50 /0.00 @:127 B@:0
Send: M105
Recv: ok T:29.03 /180.00 B:28.00 /0.00 @:127 B@:0
Send: M105
Recv: ok T:28.86 /180.00 B:27.91 /0.00 @:127 B@:0
Send: M105
Recv: ok T:29.35 /180.00 B:27.47 /0.00 @:127 B@:0
Send: M105
Recv: ok T:29.35 /180.00 B:27.94 /0.00 @:127 B@:0
Send: M105
Recv: ok T:29.49 /180.00 B:28.00 /0.00 @:127 B@:0
Send: M105
Recv: ok T:29.57 /180.00 B:27.87 /0.00 @:127 B@:0
Send: M105
Recv: ok T:30.05 /180.00 B:27.78 /0.00 @:127 B@:0
Send: M105
Recv: ok T:29.74 /180.00 B:27.94 /0.00 @:127 B@:0
Send: M105
Recv: ok T:30.26 /180.00 B:27.78 /0.00 @:127 B@:0
Send: M105
Recv: ok T:30.13 /180.00 B:27.44 /0.00 @:127 B@:0
Send: M105
Recv: ok T:30.49 /180.00 B:28.09 /0.00 @:127 B@:0
Send: M105
Recv: ok T:30.18 /180.00 B:27.62 /0.00 @:127 B@:0
Send: M105
Recv: ok T:30.65 /180.00 B:27.59 /0.00 @:127 B@:0
Send: M105
Recv: ok T:30.89 /180.00 B:27.81 /0.00 @:127 B@:0
Send: M105
Recv: ok T:30.83 /180.00 B:28.03 /0.00 @:127 B@:0
Send: M105
Recv: ok T:30.99 /180.00 B:27.75 /0.00 @:127 B@:0
Send: M105
Recv: ok T:31.30 /180.00 B:27.97 /0.00 @:127 B@:0
Send: M105
Recv: ok T:30.96 /180.00 B:27.84 /0.00 @:127 B@:0
Send: M105
Recv: ok T:31.07 /180.00 B:27.81 /0.00 @:127 B@:0
Send: M105
Recv: ok T:31.46 /180.00 B:27.41 /0.00 @:127 B@:0
Send: M105
Recv: ok T:31.74 /180.00 B:28.06 /0.00 @:127 B@:0
Send: M105
Recv: ok T:31.51 /180.00 B:27.66 /0.00 @:127 B@:0
Send: M105
Recv: ok T:31.85 /180.00 B:27.72 /0.00 @:127 B@:0
Send: M105
Recv: ok T:32.08 /180.00 B:27.87 /0.00 @:127 B@:0
Send: M105
Recv: ok T:31.90 /180.00 B:27.87 /0.00 @:127 B@:0
Send: M105
Recv: ok T:32.34 /180.00 B:27.84 /0.00 @:127 B@:0
Send: M105
Recv: ok T:32.40 /180.00 B:28.09 /0.00 @:127 B@:0
Send: M105
Recv: ok T:32.45 /180.00 B:28.25 /0.00 @:127 B@:0
Send: M105
Recv: ok T:32.24 /180.00 B:27.56 /0.00 @:127 B@:0
Send: M105
Recv: ok T:32.71 /180.00 B:27.97 /0.00 @:127 B@:0
Send: M105
Recv: ok T:32.63 /180.00 B:27.94 /0.00 @:127 B@:0
Send: M105
Recv: ok T:32.79 /180.00 B:27.53 /0.00 @:127 B@:0
Send: M105
Recv: ok T:33.10 /180.00 B:27.62 /0.00 @:127 B@:0
Send: M105
Recv: ok T:33.10 /180.00 B:27.87 /0.00 @:127 B@:0
Send: M105
Recv: ok T:33.13 /180.00 B:27.81 /0.00 @:127 B@:0
Send: M105
Recv: ok T:33.67 /180.00 B:27.94 /0.00 @:127 B@:0
Send: M105
Recv: ok T:33.67 /180.00 B:27.97 /0.00 @:127 B@:0
Send: M105
Recv: ok T:33.46 /180.00 B:27.75 /0.00 @:127 B@:0
Send: M105
Recv: ok T:33.44 /180.00 B:27.41 /0.00 @:127 B@:0
Send: M105
Recv: ok T:34.01 /180.00 B:28.03 /0.00 @:127 B@:0
Send: M105
Recv: ok T:33.70 /180.00 B:27.78 /0.00 @:127 B@:0
Send: M105
Recv: ok T:33.70 /180.00 B:27.94 /0.00 @:127 B@:0
Send: M105
Recv: ok T:34.17 /180.00 B:27.69 /0.00 @:127 B@:0
Send: M105
Recv: ok T:34.24 /180.00 B:28.00 /0.00 @:127 B@:0
Send: M105
Recv: ok T:34.32 /180.00 B:27.72 /0.00 @:127 B@:0
Send: M105
Recv: ok T:34.66 /180.00 B:28.03 /0.00 @:127 B@:0
Send: M105
Recv: ok T:34.77 /180.00 B:28.03 /0.00 @:127 B@:0
Send: M105
Recv: ok T:34.53 /180.00 B:27.84 /0.00 @:127 B@:0
Send: M105
Recv: ok T:34.66 /180.00 B:27.66 /0.00 @:127 B@:0
Send: M105
Recv: ok T:35.04 /180.00 B:28.00 /0.00 @:127 B@:0
Send: M105
Recv: ok T:35.04 /180.00 B:27.91 /0.00 @:127 B@:0
Send: M105
Recv: ok T:35.00 /180.00 B:27.81 /0.00 @:127 B@:0
Send: M105
Recv: ok T:35.29 /180.00 B:27.87 /0.00 @:127 B@:0
Send: M105
Recv: ok T:35.17 /180.00 B:27.87 /0.00 @:127 B@:0
Send: M105
Recv: ok T:35.42 /180.00 B:27.75 /0.00 @:127 B@:0
Recv: Error:Heating failed, system stopped! Heater_ID: 0
Changing monitoring state from "Operational" to "Error: Heating failed, system stopped! Heater_ID: 0 - Printer halted. kill() called!"
Send: M112
Send: N2 M112*35
Send: N4 M140 S0*97
Changing monitoring state from "Error: Heating failed, system stopped! Heater_ID: 0 - Printer halted. kill() called!" to "Offline (Error: Heating failed, system stopped! Heater_ID: 0 - Printer halted. kill() called!)"
| ABL Expert Plugin (0.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_ABL_Expert
| Bed Visualizer (1.1.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_bedlevelvisualizer
| OctoPrint Anywhere (1.1.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_anywhere
| PrintTimeGenius Plugin (2.3.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_PrintTimeGenius
| TemperatureFailsafe (0.2.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_TemperatureFailsafe
| Tempsgraph Plugin (0.3.7) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_tempsgraph
| !The Spaghetti Detective (1.0.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_thespaghettidetective
2023-08-21 18:59:29,228 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 917016576
| os:
| platform: linux2
| plugins:
| pi_support:
| octopi_version: 0.17.0
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
