After Octopi 1.0 update cannot connect through wifi
Hi, I am a noob when it comes to using raspberry pi/octopi/linux and have run into issues. Since updating to Octopi 1.0 (octopi-1.0.0-1.8.7-20230302160739 as a clean install through Raspberry Pi Imager) I have run into 2 issues. Prior to updating to Octopi 1.0 I was having no issues.
First, I have my pi (Raspberry Pi 4 B 8GB RAM) hooked up to the Raspberry Pi 7” touchscreen.
Second, is I am unable to access Octopi through SSH or the internet. I am stuck on the screen “You may now open a web browser on your local network and navigate to any of the following addresses to access octoprint: (Blank until) https is available, with a self-signed certificate.” I have not been able to connect to octoprint when this happens.
1)When trying to run octopi on it the touchscreen will not work. I have tried reinstalling (fresh install using Raspberry Pi Imager) 8 times and it will not work. I know its not the screen because I installed Raspberry Pi OS and it worked just fine. I then tried installing Octopi and it doesn’t work.
2)I am stuck on the screen “You may now open a web browser on your local network and navigate to any of the following addresses to access octoprint: (Blank until) https is available, with a self-signed certificate.” I have not been able to connect to octoprint when this happens. I got this screen the first 2 times I clean installed octopi. The 3rd time it showed me the ip address I could access it on and I was able to access it. Unfortunately, that 3rd time my touchscreen would not work so I tried a clean install of Octopi again. The next 4-5 times I did a clean install of Octopi I ran into the same problem as the first 2 times and it would not show an ip address to access it and I was unable to find it. Each time it would not show and ip address to connect to I tried connecting to every connection showed on my router and was unable to access my Octopi. When I did install Raspberry Pi OS I was able to connect to the internet.
Unable to access Octoprint to try running in safe mode in all but 1 try. The 1 time I could access Octoprint I did try safemode.
The one time I was able to access Octoprint, safemode did not solve the problem with my touchscreen not working.
Not being able to access Octopi I am unaware of how to access Systeminfo Bundle
Version: octopi-1.0.0-1.8.7-20230302160739
Printer: Prusa i3 MKS+
Personal Computer
Browser: Chrome
OS: Windows 10
I tried to get as much information as I could. If more is needed please let me know, and being a noob how to get it.
Thanks for any and all help.
*** Thanks for the help. I just got it working today by rebooting the pi by connecting a keyboard to it, sudo reboot. I kept rebooting it until is gave me an ip address to ssh into. Then as @WWR said I ran updates until I got the response that their were no more updates, 3-4 times. For those noobies like me use sudo apt-get update && sudo apt-get upgrade. After all was said and done I was finally able to access it through wifi. I have not been able to check and see if my touchscreen is working but if its not I can live with that for now.
Hello @drac2485 !
It seems it has no connection to your network.
As you are able to see what's going on on the Pi via the monitor/TV, you can attach a keyboard and type
sudo raspi-config
The default password is raspberry
There you have to navigate withe the cursor keys.
Go to point 1 by hitting the enter key
There to S1
There you check/retype your WiFi credentials.
I had a similar problem after installing 1.0.0. I found it would occasionally briefly connect to wifi and I kept trying until I could ssh into it, and then ran updates. It stayed connected through the update process and I haven’t had any problems since.
