I don't know if I have done a configuration change, but the After print job is cancelled script is not run after I press the cancel button. Anyone have an idea where I should look for?
- Run in safe mode to disable all plugin
- Add the line M300 S880 P300 at the begin of the script to generate a sound that will prove the script is run
- Check and unchecked the serial connection behaviour: Log position on cancel and Attempt to abort any blocking heatups on cancel
Yes!
Complete Logs
2020-11-13 11:36:39,101 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2020-11-13 11:38:07,474 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Cancelling"
2020-11-13 11:38:08,759 - octoprint.printer.standard.job - INFO - Print job cancelled - origin: local, path: Fresco3_lens_0.3mm_PETG_MK3S_2m.gcode, owner: _api, user: _api
2020-11-13 11:38:08,764 - octoprint.plugins.DisplayLayerProgress - INFO - Printing stopped. Detailed progress stopped.
2020-11-13 11:38:08,830 - octoprint.settings - ERROR - Exception while trying to render script gcode:afterPrintCancelled
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/settings.py", line 1620, in loadScript
script = template.render(**context)
File "/home/pi/oprint/lib/python3.7/site-packages/jinja2/environment.py", line 1090, in render
self.environment.handle_exception()
File "/home/pi/oprint/lib/python3.7/site-packages/jinja2/environment.py", line 832, in handle_exception
reraise(*rewrite_traceback_stack(source=source))
File "/home/pi/oprint/lib/python3.7/site-packages/jinja2/_compat.py", line 28, in reraise
raise value.with_traceback(tb)
File "/home/pi/.octoprint/scripts/gcode/afterPrintCancelled", line 14, in top-level template code
{% if pause_position.x is not none %}
File "/home/pi/oprint/lib/python3.7/site-packages/jinja2/environment.py", line 471, in getattr
return getattr(obj, attribute)
jinja2.exceptions.UndefinedError: 'pause_position' is undefined
2020-11-13 11:38:08,848 - octoprint.util.comm - INFO - Changing monitoring state from "Cancelling" to "Operational"
2020-11-13 11:38:08,900 - octoprint.plugins.DisplayLayerProgress - INFO - Printing stopped. Detailed progress stopped.
OctoPrint 1.4.2, OctoPi 0.17 on raspberry pi 3b, MK3S + MMU2S (mmu not connected), firmware Prusa 3.9.1
